4:11 Diff is a problem
Old Nov 11, 2011 | 08:25 PM
Revzed's Avatar
Revzed
6th Gear
Default 4:11 Diff is a problem
Hey guys - Just recently purchased my first Corvette, it is a 1973, 454, 4 speed. It has a 4:11 Diff ratio which gives it plenty of punch but makes it hard to drive over distance. Would appreciate if anyone can give advise on what ratio would be best (I was thinking around 3:7?) and any info on where I can get this as a used or recon component.
Appreciate any help you can give.
Cheers,
Rev.
Old Nov 11, 2011 | 08:46 PM
bop's Avatar
bop
I had a 71 with a 370 and had lots of get up and go but still ran highway speeds ok. My 71 that I own now has a 355 and I really like the 370 gear better. You may find someone on the Forum that will swap rear ends with you.
Old Nov 11, 2011 | 08:50 PM
Revzed's Avatar
Revzed
6th Gear
Thanks for the heads up! I just saw a 3:7 in the for sale so I'll chase that up. Appreciate your help.
Rev.
Old Nov 11, 2011 | 09:53 PM
54greg's Avatar
54greg
3.73 are my favorite
Old Nov 11, 2011 | 09:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
Thats only going to drop your cruise rpm a small bit.
Ever consider a 5 or 6 spd?
Old Nov 11, 2011 | 11:10 PM
Red 69's Avatar
Red 69
Thats only going to drop your cruise rpm a small bit. Ever consider a 5 or 6 spd?
This is good advice, going from a 4.11 to a 3.7 will accomplish little. A much better change would be to an OD transmission. You will get the highway cruise gear, without sacrificing get-up and go.
Old Nov 12, 2011 | 02:36 AM
Bangkok Dean's Avatar
Bangkok Dean
My 3:73 was a bear on gas and the motor with the 4 speed, now with a 5speed (.80 OD) it still has the getup and scare you plus the enjoyment on the highway trips.
Old Nov 12, 2011 | 09:45 AM
69 Chevy's Avatar
69 Chevy
http://www.ikerds.com/catalog/group16/group16.html
Old Nov 12, 2011 | 10:21 AM
joewill's Avatar
joewill
4.11 to 3.73 will not drop your rpm that much... less than 10%.. swapping gears costs alot of money and lots of hassle for such a minor incremental.
if you go with a 5 or 6 speed, you will find that 1st gear with a 4.11 will be such a granny gear that you won't use it. you will catch yourself starting off in 2nd.
you might want to consider a philosophy change similar to mine.. I bought my car with a 4.11 and swapped it out with a 2.73. it practically idles down the highway and my 454 has plenty of power to pass when I need it or to get around someone.
it just won't do donuts in the parking lot... but that is not how I treat my cars anyway.
IMHO...
Old Nov 12, 2011 | 11:12 AM
jb78L-82's Avatar
jb78L-82
Again, I agree that going from 4.11's to 3.70's which I have with my 4 speed is not going to do much for you. I think the best solution is a 5 speed with an overdrive which will give you the best of both worlds BUT it costs to me big money for that luxury! Unless you plan on doing a lot of highway driving, I would not spend the $'s on the 5 speed. The last time I looked the 5 speed was going to cost me about $4,000 to do the conversion myself. I know that many have done it for less but you know how these types of projects can go. If you are not planning to drag race or autocross the car, I think that I would look to beef up the 454 for relatively cheap dollars and would go with the 3.08 gears since the BB has great torque! Personally, I wish I could ditch my 3.70's for the 5 speed since I really have tired of the engine turning 3,500 RPM at 70 mph and close to 4K at 80 MPH after 28 years of owning the car. It gets old especially with a beefy exhaust like I have-maybe I am just getting too old for it anymore?
Old Nov 12, 2011 | 11:50 AM
Solid LT1's Avatar
Solid LT1
I'd go with a 3.55 ratio for that big block or a 3.36. You will have to change the ring gear carrier so major cost involved to change gears.
To 4:11 Diff is a problem
