69 427 Carburetor Replacement Sugestion Source
The previous owner messed with the carb quite a bit including removing the choke mechanism.
I've decided the easiest solution is to replace the carb with a correct Quadrajet.
Is it possible to but a new or remanufactured carb with the correct numbers to match the year of engine?
Any suggestions where to buy?
Many thanks, Charles Rahm, Dallas
