Leaky calipers???
Old Nov 12, 2011 | 07:07 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default Leaky calipers???
When I put my '77 back on the road after 5 years of storage I had to bleed the brakes 3 times in the first 6 weeks, and replaced one caliper due to a leak. They went 6 months w/ out needing bleeding then almost a year. When I bled them today the rear calipers were "damp" near the back of the pads but definately not a leak. I check the fluid level monthly and have never had to add any. I may buy a pair of the o-ring calipers in the spring, what do you guys think?
Old Nov 12, 2011 | 07:18 PM
Cleon's Avatar
Cleon
My 1979 was doing the same thing. The origional calipers are all steel. The brake fluid absorbes water and they rust. I replaced all four with VBP stanles O ring and have had no problems.
Old Nov 12, 2011 | 07:23 PM
Ganey's Avatar
Ganey
If you have SS calipers just rebuild w/ O-Ring piston kit, fast & easy.
Old Nov 12, 2011 | 07:24 PM
7t9l82's Avatar
7t9l82
i couldn't agree more
Old Nov 12, 2011 | 08:16 PM
babbah's Avatar
babbah
Old Nov 13, 2011 | 06:18 PM
BPHORSEGUY's Avatar
BPHORSEGUY
OK, The calipers have no visible rust on them but I have a very clean frame! I haven't taken a magnet to them yet but how do I determine if they are stainless, I have only owned the car for 2 years. The receipts I got from the PO do not show any new calipers !
Old Nov 13, 2011 | 06:40 PM
Ganey's Avatar
Ganey
By SS we mean SS sleeves in the calipers, see the pics. in this topic.
http://forums.corvetteforum.com/c3-t...-calipers.html
One way to find out would be to pop a seal & push the piston in to see if it has the bright SS sleeve.
Old Nov 13, 2011 | 06:50 PM
Stoge's Avatar
Stoge
Did you bleed your brakes today for preventative maintenance, or did you do it due to soft pedal?
This is just an idea, but have you checked your rotor runout? Even if you have stainless steel sleeved calipers with o-ring seals, you can still get a little bit of air pumping past the seals if your runout isn't within spec. If you have lip seals, then it is very easy to get air past the seals. At the same time, it is possible to have this happen while having little to no fluid leaking out of the piston bore(s).
Old Nov 13, 2011 | 08:25 PM
mds3013's Avatar
mds3013
Here is how I rebuilt mine. mike...
http://forums.corvetteforum.com/c3-g...-calipers.html
Old Nov 13, 2011 | 10:28 PM
BPHORSEGUY's Avatar
BPHORSEGUY
I bled them due to a soft pedal. I am familiar w/ the seal flutter 'theory" but most of the brake experts I know dismiss it as internet rumor. It does fit my exact scenario though as I had done some highway driving just prior to the soft pedal. I know my driver's side rear is in spec but maybe I will check the other next time. I only had to bleed the rear to get my pedal back.
Old Nov 13, 2011 | 10:42 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Thanks Mike !
Old Nov 14, 2011 | 09:38 AM
gcusmano74's Avatar
gcusmano74
Rotor runout, caused by a warped rotor or a loose wheel bearing, will have you bleeding your brakes constantly. The o ring sealed calipers will tolerate a bit more runout than the origional lip seal type.
Years ago, I had a piston rust up and freeze in a front caliper. The clamping of the rotor, then, was only working on one side of the rotor. The uneven heating warped the rotor. I needed a fresh rotor and a rebuilt caliper.
To Leaky calipers???
