9.5-1 Compression what will it do?
Old May 6, 2002 | 08:18 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Default 9.5-1 Compression what will it do?
I was looking to upgrade the heads on my car. Edelbrock has the Performer RPM heads thta knock it up to 9.5-1. I know this will be a big kick in the butt w/ power, but there are two choices, 64 and 70 cc heads. Which one would be better for me? Also what will it dow gas mileage wise?
Old May 6, 2002 | 09:47 PM
RMS73's Avatar
RMS73
Default Re: 9.5-1 Compression what will it do? (DCBStingray)
Could 30 Hp per 1 point of compression increase ,but depends on cam intake, exhaust etc. The use of a 64cc or a 70cc combustion chamber will affect the CR. The 64cc will increase the ratio more than the 70cc.
Roger
Old May 6, 2002 | 10:06 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
With everything else being equal, higher compression should improve mileage slightly. If all is well with the rest of the engine, a 9.5 cr should work ok with regular grade fuel also.
To 9.5-1 Compression what will it do?
