Another winking headlight question
Old Nov 14, 2011 | 06:42 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Default Another winking headlight question
I recently replaced most of my headlight vacuum system and now have working lights. It's new from the dash to the relays and actuators, including all hoses and headlight switch. However, one headlight will partially raise and lower under acceleration occasionally but not consistently. I used the forum search and did as much troubleshooting as I could with my handy dandy vacuum pump and visually checking the system. Any other ideas? By the way, I'm still working on getting all the interior hvac system to work and might have a leak there if that would have a bearing on the problem. Thanks for your help.
Old Nov 14, 2011 | 06:57 AM
TedH's Avatar
TedH
Check the vacuum system connections. Any cracked connectors? I had a power brake booster connector that was cracked and I would drop vacuum. Dr Rebuild has most connectors that you would need. They get brittle with age. Even the pot metal 2 or 3-way vacuum fitting in the port on the intake, aft of the carb, cracked on my C3 and I got a good replacement from the good Dr. I found that replacing all of the vacuum hoses/fittings AND removing/bypassing the thermal sensors on the intake (they control/limit vacuum until the engine is warm) made an incredible difference and I have reliable vacuum signal now; 14 years and counting.
Old Nov 14, 2011 | 07:07 AM
CaseyJones's Avatar
CaseyJones
I will definitely check all connections. All hoses and connectors are new, but I'll go back over it more carefully.
Old Nov 14, 2011 | 09:24 AM
C6DuffMan's Avatar
C6DuffMan
It sounds like the check valve to me. The system shouldn't lose vacuum under load.
Old Nov 14, 2011 | 11:10 AM
78IndyPace's Avatar
78IndyPace
Agree. Remove the check valve, put it to your lips and attempt to blow through it from the manifold side (single large port). If you can blow through it, it is defective.
Old Nov 14, 2011 | 11:54 AM
Peterbuilt's Avatar
Peterbuilt
Many times its the seal in the actuator that goes bad:
How to test:
http://www.corvette-101.com/vacuum.htm#actuator
Old Nov 14, 2011 | 03:35 PM
CaseyJones's Avatar
CaseyJones
New relays and actuators. New hoses. New filter. New check valve. New headlight switch. I'll check the valve just in case and make sure the hoses are all on tight. Otherwise, I'm out of ideas. By the way, the headlight that winks also opens the quickest. Go figure. Thanks for the suggestions so far.
Old Nov 15, 2011 | 12:23 AM
Peterbuilt's Avatar
Peterbuilt
Seems like everything on the vacuum side is new and if each component tests good then you might want to see if you have 4 springs and that all the pivot points more freely.
To Another winking headlight question
