Header Heat
Old Nov 14, 2011 | 09:41 AM
boat196's Avatar
boat196
Default Header Heat
The header is within an inch of the a/c housing. Could the heat from the header cause damage to the a/c housing.
Bob
Old Nov 14, 2011 | 10:41 AM
MelWff's Avatar
MelWff
To be save try wraping the pipe with an insulator such as these
http://www.summitracing.com/search/D...ord=insulation
Old Nov 14, 2011 | 12:25 PM
Roco71's Avatar
Roco71
Bob
Yes, it will cause the heater box to deteriorate in that corner. I had to repair mine from damages from the previous owner
Old Nov 14, 2011 | 03:33 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I insulated the entire box with some adhesive-back insulation, I did that after I fixed a whole in the size of a tennis ball that was formed because of the heat.
To Header Heat
