Headlight actuator pivot pin frozen
Old Nov 14, 2011 | 11:07 PM
Turbotrad's Avatar
Turbotrad
Default Headlight actuator pivot pin frozen
I'm trying to remove one of my headlight actuators and cannot get the pivot pin to budge. It's stuck in the end of the actuator rod.
Any ideas? The pin "should" slide right out, but mine is frozen in place. Won't even budge with some persuasion from a brass hammer.
Old Nov 15, 2011 | 09:44 AM
Turbotrad's Avatar
Turbotrad
I'm hesitant to try using a torch since the actuator is still inside the car and the only other thing I can think of is trying to get some penetrating oil working on the stuck pin.
Any other ideas?
Old Nov 15, 2011 | 10:26 AM
Peterbuilt's Avatar
Peterbuilt
All these pins should slide in and out. Penetrating oil should help.
Which pin is giving you the problem?
Old Nov 15, 2011 | 10:09 PM
Turbotrad's Avatar
Turbotrad
Number 6, it's stuck in the rod clevis and will not budge. I'll try some penetrating oil and see if that helps.
Old Nov 19, 2011 | 08:39 PM
Turbotrad's Avatar
Turbotrad
Done. Removed the pin.
Sprayed with PB Blaster penetrating oil and then torched with a Bernzomatic propane torch 30 mins later and with some persuasion from a pair of vise grips the pin came out.
Now I just have to clean it up.
Old Nov 19, 2011 | 08:46 PM
V4motorsports's Avatar
V4motorsports
Check number 5 & 7. Make sure you didn't melt either one. Only made out of nylon.
Hope this helps
Russ
Old Nov 20, 2011 | 06:27 PM
Turbotrad's Avatar
Turbotrad
I just finished removing all of the pins and levers for cleaning and re-painting.
I'm not sure how helpful the penetrating oil was, but the torch was absolutely essential. My pins were so stuck that only melting out the nylon bushings could get the pins out.
Lucky for me I have bushings and springs being delivered tomorrow.
I'll have the actuator seal replaced tonight and hopefully painted as well.
This all started because I needed to replace the actuator front seal in preparation for installing the speed direct never night harness and lights...
My actuator seal looked like a shredded balloon after you pop it...pretty sure I pinpointed the problem...
Will the "while I'm at it" fever go away?
Old Nov 20, 2011 | 06:30 PM
Turbotrad's Avatar
Turbotrad
I'm definitely lubing everything up with lithium grease and silicone before it goes back together.
On the bright side...this has been yet another excuse to go out and buy tools!
To Headlight actuator pivot pin frozen
