ground wire
Old Nov 16, 2011 | 08:07 PM
tim bob's Avatar
tim bob
Default ground wire
any body know were the ground wire on a 76 drivers side bottom of the raideator goes i took it apart some time ago to swap out my cam cannt seem to remember were it goes thanks tim bob
Old Nov 16, 2011 | 08:19 PM
Tim H's Avatar
Tim H
Bolts to the core support.
Old Nov 16, 2011 | 09:12 PM
tim bob's Avatar
tim bob
so it goes between the raideator frame and the frame of the car or just on the side of the bolt were the bolt goes into the hole if that makes sense?? thanks alot tim bob
Old Nov 17, 2011 | 01:44 AM
Tim H's Avatar
Tim H
My ground wire came out of the wiring harness and bolted to the lower front (towards the headlights) side of the radiator core support.
Where it comes from in the harness I don't know, I just know where I unbolted and bolted back up.
I don't think it matters where you bolt it to , I think what its doing is grounding the radiator support to the car because the bolts holding it to the car is only going thru fiberglass, so in a nutshell you need a ground wire from the radiator support to the frame of the car.
Old Nov 17, 2011 | 05:36 AM
tim bob's Avatar
tim bob
thanks tim i will put on today
Old Nov 18, 2011 | 10:38 PM
tim bob's Avatar
tim bob
tim i tried to put the wire on still alittle confused i tried to put it on but the eye of the wire wouldnt fit threw the bolt i was putting it on the lower bolt by the drivers side wheel well ??????? i just want to make sure i get it right thanks tim bob
Old Nov 19, 2011 | 05:01 AM
dembo's Avatar
dembo
Hi,
I don't know if we are talking about the same ground and if the position has changed (mine's a 74). But the picture below I took looking in between the open hood and the radiator support, so the top of the pic is towards the front of the car. In a 74 there's a hole in the shroud for the ground.
Nick
Old Nov 19, 2011 | 07:23 AM
Tim H's Avatar
Tim H
Originally Posted by dembo
Hi,
I don't know if we are talking about the same car and if the position has changed (mine's a 74). But the picture below I took looking in between the open hood and the radiator support, so the top of the pic is towards the front of the car. In a 74 there's a hole in the shroud for the ground.
Nick
BINGO!!!!! Good pic.
Old Nov 19, 2011 | 10:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The forward lamp harness for all C3s grounds on the front side of the radiator support as shown. This location is under the nose, not in the wheel well.
Old Nov 19, 2011 | 06:28 PM
tim bob's Avatar
tim bob
thanks man awesome pic i was confused i have a 76 with ac but im going to put mine in the same spot thanks to all tim bob
Old Nov 20, 2011 | 11:13 AM
Easy Mike's Avatar
Easy Mike
Yours would have been pretty much in the same spot. You'll find the bolt hole in the radiator support. Clean the harness connector and the support for good contact.
Old Nov 20, 2011 | 11:35 AM
tim bob's Avatar
tim bob
thanks everyone i will do just that what i did was rebuilt it when i removed it the core support it was all rusted out but i think i see a hole .
Old Nov 20, 2011 | 01:45 PM
dembo's Avatar
dembo
Glad you found it
To ground wire
