Transmission no worka so good
Old Nov 16, 2011 | 10:35 PM
knevil's Avatar
knevil
Default Transmission no worka so good
I HAVE A 72 VETTE WITH a 4 SPEED . My problem that when I shift to third gear it feels like maybe the shifter is not pushing into 3rd gear all the way .After I reshift a couple of times it will go all the way in gear and work fine . I am hoping it is an easy fix but I'm afraid it is the gears . Transmiision doesn't make any noise . any info or help will be appreciated very much . I would like to thank ahead of time for any help with this problem
Old Nov 17, 2011 | 07:48 AM
C3 4ME's Avatar
C3 4ME
I would start by making sure the shifter is properly adjusted
Old Nov 17, 2011 | 09:48 AM
knevil's Avatar
knevil
Thanks am heading to garage right now to check this out .
Old Nov 17, 2011 | 12:12 PM
Phil Zell's Avatar
Phil Zell
Make sure the shifter bracket is tight before adjusting linkage
Old Nov 17, 2011 | 11:29 PM
knevil's Avatar
knevil
Well I got lucky all that was needed was an adjustment of the shift rod .Thanks for the advice you guys . I was not looking forward to pulling the transmission are paying for a rebuild . C3's Rock !!!!
Old Nov 20, 2011 | 01:12 PM
knevil's Avatar
knevil
Back again with transmission questions as stated earlier I thought I solved my transmission problem . Upon testing the fix I found thaat sometimes it shifts fine other times not so fine any suggestions
Old Nov 20, 2011 | 03:56 PM
Duane4238's Avatar
Duane4238
If after your first adjustment it works some of the time, I'd say you are on the right track. Get back under there and check the adjustment, again, and also make sure that everything is well lubed up. A lot of guys forget to lube the shifter assembly as part of preventive maintenance. Good luck and keep us posted.
Duane
To Transmission no worka so good
