Straight Line Issue
Old Nov 17, 2011 | 09:23 AM
gcarpenter's Avatar
gcarpenter
Default Straight Line Issue
When I hit the gas hard on my '73, the nose of the car veers to the left. The opposite happens when I let off quickly, the nose pulls to the right. I had the differential rebuilt last year. I'm thinking it may be an alignment issue with the front or rear end and hoping it's not the differential. Tires are not showing wear. Any ideas?
Old Nov 17, 2011 | 09:39 AM
wombvette's Avatar
wombvette
Usually a case or thrust angle. Have the alignment checked and look at bushings and shims.
Old Nov 17, 2011 | 12:08 PM
Phil Zell's Avatar
Phil Zell
Your trailing arm bushings are shot.
Old Nov 17, 2011 | 12:52 PM
gcarpenter's Avatar
gcarpenter
Are these easy to replace? Is there going to be tension on this when jacked up?
Old Nov 17, 2011 | 09:11 PM
gcarpenter's Avatar
gcarpenter
You were dead on. The driver's side trailing arm bushing has 1/2" of play in it. Doesn't look very easy to change.
To Straight Line Issue
