Torque Specs for '82
Old Nov 19, 2011 | 05:37 PM
scorpion18z's Avatar
scorpion18z
Default Torque Specs for '82
I see a vary large range for the torque specification of the oil pump bolt (45 ft lbs to 65 ft lbs). Also, oil pan bolts (small laterals) and (4 larger corner bolts)...90 to 103 in lbs. Will anyone give me a heads up on this? It would be appreciated.
Old Nov 19, 2011 | 05:56 PM
billla's Avatar
billla
St. Jude Donor '14
GEN I SBC, right?
65# for the oil pump bolt.
Around 100-110 lbs-in for the corner bolts and 70-80 lbs-in for the rest - it's not a precision torque rating, but more to keep folks from over-tightening
The temptation is to significantly over-tighten these bolts, but that's generally the cause of the gasket shifting and causing leaks.
Old Nov 19, 2011 | 06:40 PM
scorpion18z
Thank you billa. Much appreciated. You guys are good on this forum.
To Torque Specs for '82
