Auto Transmission shifter modification. Pics
Old Nov 19, 2011 | 10:07 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Auto Transmission shifter modification. Pics
I really don't care for the plastic slide on the automatic transmission shifter on C3's. So I decided to try and fix it. First, I purchased a used auto shifter plate on ebay....didn't care what shape it was in. Second, I cut out the section on the plate where the shifter goes through (which is made up of the HARDEST substance known to man...it took 1 hour with a Dremel!!!) Third, purchased the "no-mar" wood grain from Zip-Corvette for the plate. Fourth, purchased the 4-speed manual shifter boot from Ecklers. Fifth, JB welded the boot base to the plate from the bottom and VOWLA! a modification that works!!
:cool:
Old Nov 19, 2011 | 10:09 PM
'75's Avatar
'75
I like it, good job!
Old Nov 20, 2011 | 11:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
After all that work, why not use the correct black trim screws for the console?
Old Nov 20, 2011 | 04:19 PM
vetteguy75's Avatar
vetteguy75
That's what I thought I could do but the auto transmission plate hole (when you cut out the housing for the plastic slide) is smaller than the 4 speed plate, so the boot was too big for the opening.
Old Nov 20, 2011 | 11:55 PM
Brass Pass's Avatar
Brass Pass
Looks good!
Old Nov 21, 2011 | 09:02 AM
929nitro's Avatar
929nitro
I like it. Very nice job.
To Auto Transmission shifter modification. Pics
