electrical problems
Old Nov 21, 2011 | 05:32 AM
79rallypack's Avatar
79rallypack
Default electrical problems
Hi i have just purchased an 81 corvette and I am trying to find a good wiring diagram as the car has no horn and i can not find any wires that may show where it was, also some of the gauges do not work, I also need to change the indicators on the rear as we can not have red turn signals in Australia must have orange, to do this i must change the reversing lights to become the indicators and use a orange light bulb, i believe this is done at the steering wheel some how?? can anyone help with detailed wiring diagrams ?? Thanks
Old Nov 21, 2011 | 07:06 AM
Tim H's Avatar
Tim H
http://stores.ebay.com/ClassicCarWir...id=p4340.l2563
laminated and clear to read, i have bought 4 or 5 off him.
Old Nov 21, 2011 | 07:13 AM
scottw's Avatar
scottw
you can use doc rebuild diagrams as well. That is what I used when I replaced my wiring harness. PM papawana and he will email you a wiring diagram. I couldn't read it as well as the doc rebuild but it is a very detailed diagram.
Old Nov 21, 2011 | 07:36 AM
John 65's Avatar
John 65
With the Doc Rebuild, it shows pics of every wire clip and wire connector from the harness, which really makes it ez.
Old Nov 21, 2011 | 09:12 AM
Radialhead's Avatar
Radialhead
I had to do the same with mine (I'm in the UK). I redirected the wires at the back of the car. I.e. cut both turn signal & reversing lights +ve feeds, then attach the turn signal wires to the reversing lights.
I can't imagine why you'd want to do it at the steering wheel, even if there are separate feeds going to each reversing light, which seems a bit unlikely.
Old Nov 21, 2011 | 09:37 AM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
Here's a free black & white schematic:
http://www.nrjvette.com/johdotukset/...tte%201981.pdf
Look up Jim Shea's papers for horn troubleshooting.
Willcox has a "how to" for troubleshooting the gauges in his "help & repair section.
Enjoy your new Vette.
Old Nov 21, 2011 | 09:22 PM
79rallypack
Thanks for the help it should get me going in the right direction.
To electrical problems
