fuel gauge problem
Old Nov 22, 2011 | 03:12 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
Default fuel gauge problem
Hello. I recent purchased a fuel tank sending unit for a 79 vette. I pre tested it before sticking it in the tank to verify if the gauge worked, and the gauge still did not read correctly. I have check resistance through the sending unit and it was 0-100 ohms. I used new seperate wires (ohm wire and ground) to go from the sending unit to the gauge and still did not get a correct reading. If i touch the ohm wire to the ground wire at the sending unit my gauge will go full range across the gauge (though the low fuel light never comes on it does go from empty to past full). Anyone have any idea what i can check next or what my problem might be?
Old Nov 22, 2011 | 03:14 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
With the key in the on position, what does the gauge read?
Willcox
Old Nov 22, 2011 | 06:08 PM
joshtried's Avatar
joshtried
Key on sending unit hooked up it reads just above redline empty
Old Nov 22, 2011 | 10:30 PM
0Willcox Corvette
Former Vendor
You have a ground issue..... double check your sending unit ground and if this doesn't correct the issue look at the printed circuit in the dash.
Willcox
To fuel gauge problem
