Throw out Bearing arm
Old Nov 22, 2011 | 08:52 PM
newbie2vette's Avatar
newbie2vette
Default Throw out Bearing arm
I think I have the answer to my question, but I thought I would verify it. Can someone share a photo on how the throw out bearing arm is mounted or being held in place on the bell housing? thank you.
Old Nov 22, 2011 | 09:03 PM
Steve2147's Avatar
Steve2147
I don't have a pic, but it's pretty easy to describe. The socket in the fork sits over the ball that's on the bellhousing. The fork as a fork shaped steel spring clip riveted to it that holds it in place. You slide the ball between the fingers of the clip and it snaps it into place.
What may be causing you difficulty is that often the clip is broken with only one finger, or no fingers leaving you to wonder what the neck holds it in place.
Steve
Old Nov 22, 2011 | 10:48 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Here's another one that people seem to goof up on.
Old Nov 22, 2011 | 11:53 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Thank You Ben, ask me how I learned this one !
Old Nov 23, 2011 | 12:29 PM
newbie2vette
Looking at that photo, I did not see any clip on the arm. Then again I was not looking for a clip to hold it, I was focusing on a bolt from behind the bell housing. I will check and come back with the result. thank you
Old Nov 24, 2011 | 07:29 AM
gcusmano74's Avatar
gcusmano74
A clip is riveted onto the clutch fork. It grabs the ball stud. The clips are known to break off. Get a new clip and rivet it back on. Among others, Zip sells the parts (CL-175).
Old Nov 24, 2011 | 11:38 PM
A-Lo 71's Avatar
A-Lo 71
Does this help?
Old Dec 22, 2011 | 08:45 AM
newbie2vette
Yes, thank you. I finally got it back together after being painted. that spring was though to get back on the pivot bolt.
Old Dec 22, 2011 | 07:34 PM
Black C3 Vette's Avatar
Black C3 Vette
Probably better off just buying a whole new clutch fork. Just picked one up from Summit yesterday, they had them ranging from $15 to $100. I picked up the McLeod Racing one for $34.
Old Dec 23, 2011 | 11:20 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
bought my clip from Wilcox...
To Throw out Bearing arm
