Lower control arm mount problem
Old Nov 23, 2011 | 09:56 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Default Lower control arm mount problem
The lower control arm brackets have torn loose from the frame on my 80. This is not a rust or collision related problem as my frame is straight and solid. I was told by another member that this is not uncommon for gymkhana cars and I have the basic instructions on making repairs. However, I don't want to do it more than once. Have any of you had or heard of the problem and are there special steps that will make the repair permanent?
Old Nov 23, 2011 | 10:14 PM
esierra's Avatar
esierra
I had a 74 Vette that the welds broke loose in a auto-cross, Im currently doing a frame off on another vette and per this forum got some pics on adding gussets to that area. Do a search and hopefully you can find it, It had lots of pictures on different places to beef up the frame. Good luck, E
Old Nov 23, 2011 | 10:34 PM
esierra's Avatar
esierra
Hope this helps,
http://forums.corvetteforum.com/c3-t...arge-pics.html
or do a search for, What frame mods did i miss?
To Lower control arm mount problem
