Just changed out my rear 300 lb (VB&P) composite rear spring to a Hyperco 200 lb composite spring, to improve the ride and adhesion. I'm not 22 any more. Heck, I'm not even 52 any more.
At any rate, while I had everything apart, I discovered that my tried and true (maybe 20 years old!) Delco Gas Cushioned Performer shocks were leaking.
I went to the parts counter, and they don't make that particular shock any more. The replacement available today is not the same.
Somebody told me try the Bilstein Sport, but they are a bit pricey.
What's the good shock today, for this spring?
Using the KYB shocks myself. Changed fronts last year, doing the rears this winter.
VB&P have a "special" KYB made for mono-leaf springs (I actually just bought a set from a forum member) that are supposed to be matched for the composite spring.... I'm not sure how much that matters on the street but that's what I ended up with.
Mooser
I installed Koni's all around. But I figured I'd probably live long enough to be able to utilize their 'adjustable for wear' feature. Their tech line is open every week day. I'm sure they could answer your questions.
KONI North America
1961 A International Way
Hebron, KY 41048
Phone: 859-586-4100
don't get the KYB's with a composite spring... I had the "special" KYB's also, they absolutely do NOT have the ability to properly control the rebound in that spring. Been there one that... if you don't like the ride of the Sports, get the Bilstien HD's...but never KYB's...
From: Graceland in a Not Correctly Restored Stingray
No reason to put stiffly valved shocks on such a softly sprung car, so if you go with the Bilstein, I'd opt for HD's rather than the Sports. FYI, ride comfort and high-performance handling tend to reside on opposite ends of the bar/spring/shock spectrum.
I got Bilsteins Sports with what I believe is a 355 TRW spring and the ride is good but I was thinking of going for something a bit less stiff. I didn't know there was a 200# spring avail. Got a link??? Or where did you get them?
For a 200 spring I would think any good quality gas shock would do.
TSW
I just purchased bilsteins from Van Steel and he said the HD's are discontinued. He also said the rebound rate was only about 10% difference between hd's and sport.
I have KYB Gas-A-Just shocks in front on my '81 and what looks like red Gabriels (no label on them) in the rear with the factory metal spring. I love the ride and so far my friends do too.
Hypercoil makes the 200# composite spring. They call it an EZ Ride. See hypercoils.com. Eckler's sells them, as well as, I think, Van Steel and some race shops. The center of the spring, however, is wide. I had to use 7/16 bolts with special bushings to mount it to the differential on my '74. Also, the clearance between the spring leaf and the exhaust pipes is tight.
The stock multileaf steel spring has so much interleaf friction that it is, to a large degree, self damping. So the shock designed to work with that steel spring has a bit of an "easier time" of controlling it. The composite spring can be quite bouncy with the wrong shock- you need to find a shock with a lot of rebound resistance.
The next step up in stiffnes for the composite springs are the Vette Brake's 300#. Hypercoil also makes a 315# and a 330#, if I recall correctly. Changing the spring rate on only one end of the car will also change the understeer/oversteer balance, as well as effecting the ride and adhesion.... .
You can wind up chasing your own tail, if you are not careful and thoughtful.
Only 10%? Wouldn't have thought they'd be that close. Still, I can't see putting stiffer shocks on a car where soft ride is the primary goal. If they're no longer available I guess the old HD's I have stashed away might become worth having saved afterall.
I love my Bilstein HD's with stock front srpings and the 350 lbs VBP rear spring. The car is very stable in turns and corners, but the ride isn't "stiff".
