Part # question for a '73 AIM
Old Nov 24, 2011 | 02:35 PM
Paul71LT1's Avatar
Paul71LT1
Default Part # question for a '73 AIM
Does anyone out ther have a Assembly Instruction Manual for a 1973 that can check a part number for me. I need to know is Part #3956118, lower fan shroud extension is the right part for a small block car? I recently bought a '73 convertible and found that the lower extension is missing. There's one posted here on the forum advertised as for '70 to '72 and I'd like confirmation that it will also fit my '73 before I pursue it.
Thanks for the help!
Old Nov 24, 2011 | 02:45 PM
vanice's Avatar
vanice
In my book I see 70-72 w/350 and 71 w/ HD/Rad
Old Nov 24, 2011 | 03:04 PM
Blue73Shark's Avatar
Blue73Shark
The lower shroud extension was for a 454 engine. The small blocks had a complete "circle" extension. Check this out from Paragon:
Small blocks:
https://www.paragoncorvette.com/p-35...extension.aspx
Big block 454
Old Nov 24, 2011 | 07:36 PM
Paul71LT1's Avatar
Paul71LT1
Default thanks
Thanks for the help guys. Although mine is a small block car with a '74 dealer replacement engine, I do have the composite shroud. It appears to be very much like the shroud in my '71 LT-1, but I can't compare at the moment as the '71 is a couple miles away in a borrowed garage! I will have to keep looking and I guess I should find out what the GM part number is for the big block shroud which is what I may have.
Old Nov 24, 2011 | 10:09 PM
gbvette62's Avatar
gbvette62
There is no "big block shroud", for 73-75. All 73-75 Corvettes use the same shroud. The only difference between the big block and small block shrouds, is the extension that was used on them. The part number for the 73-75 shroud is 339175. This shroud was also used on 70-72 big blocks with air.
The small block shroud extension is part #331870, and is used for all 73-75 350's. The 73-74 big block extension is part #336152.
Old Nov 25, 2011 | 03:06 PM
71rdster's Avatar
71rdster
I don't have the 73 AIM, and GM is known to change part numbers. I have a PDF copy of the 53 - 82 parts manual, and it confirms the 73-75 shroud part # of 339175. I get different part numbers for the lower extensions. #327695 for the small block, and #336176 for the big block.
I know that just muddies the water.
Old Nov 25, 2011 | 03:36 PM
Mike Ward's Avatar
Mike Ward
The AIM is not always the best reference. The sheets reflect a single point in time when the part number was in use. There could be umpteen previous or subsequent part numbers.
Old Nov 25, 2011 | 07:09 PM
gbvette62's Avatar
gbvette62
I'm pretty sure the numbers I posted are correct, and have never been changed or superseded, that I'm aware of.
I have about a dozen original (printed paper) Corvette Parts Books, dated between 1970 and 1983, as well as a microfiche edition. Though I didn't check all of my Parts Books, both my Sept. 75 and Sept. 83 dated editions, show the same part numbers, as I previously posted.
I don't have an open 73 AIM, but my 74 AIM also lists the same part numbers for the extensions (331870 small block and 336152 big block).
I also have 2 NOS big block extensions on my self, and both have 336152 molded into them.
Old Nov 25, 2011 | 07:47 PM
Mike Ward's Avatar
Mike Ward
That must hurt?
I see shroud part number 331869 listed in the judging guide, 1973 only.
Old Nov 25, 2011 | 10:22 PM
RU7376vettes's Avatar
RU7376vettes
Mike:
I have 73 AIM. Sheet 13-E -1 Lists Shroud as 3956108. Extension for L48/LT1 as 3956118. Sheet 13-E-2 Lists extension 3974014 as the one for the LS4. My 73 has L82 and has the correct extension on it. It currently is in one of my other garages so I can't send you photo tonight.
Unk
Old Nov 25, 2011 | 10:34 PM
RU7376vettes
Paul/Mike
I found picture in my files that shows the shroud extension.
[/IMG]
The part number Paul listed is the same one in the 73 AIM.
Unk
Old Nov 25, 2011 | 10:46 PM
gbvette62's Avatar
gbvette62
Originally Posted by RU7376vettes
Mike:
That's interesting, as my Sept. 75 Corvette Parts Book lists the 3856118 extension only for the 70-72 350 with plastic shroud, and the 331870 as 73-75 350.
Of course, 73 didn't have an LT-1, as an option, so it's could be an early sheet, that was later revised?
Unk
This part number doesn't show up in anything I have. I don't have a 73 or 74 parts book, the ones I have jump from Sept. 72 to Sept. 75. Sooner or later I have to find a 73 or 74 book, as that's the only 2 year gap I have Parts Books, between Jan. 70 and Sept. 83.
Old Nov 26, 2011 | 01:35 AM
Mike Ward's Avatar
Mike Ward
OK, we're all officially confused now.
Old Nov 26, 2011 | 08:18 AM
mark6669's Avatar
mark6669
I have found Dr Rebuild to be a good source for shroud info his catalog has pictures of all the C3 shrouds and extensions. Just another opinion to add to the confusion!
Mark
Old Nov 26, 2011 | 10:35 PM
RU7376vettes
It is hard to argue with an AIM that has numbers that match an actual 73 car! The original posting was asking if the number was correct for a 73 per the 73 AIM. The same AIM drawing I referenced is shown in the NCRS 73 judging guide on page 81 Figure M 5.0. The drawing showing extension number 331870 is shown on Page 82 Figure M5.1 and is stamped "Cancelled".
The confusion seems to be the result of people trying to use other documents than the one requested in an attempt to provide an answer.
Since it was questioned, the date on the 73 AIM manual drawing listing the part numbers shows the drawing was made on March 17, 1972 as the result of an Engineering Change Request number 43746 that was dated February 15, 1972.
The fact that an earlier or later Parts Listing for multiple years shows something else just shows why those lists may not show it all. I have had dealer parts people tell me something didn't come up on their list, but when we dig into their old records we find the number was correct.
If you want a real exercise in multiple numbers for a given year, check out the fan shroud situation for a 76, they made a change mid year.
Unk
To Part # question for a '73 AIM
