I have a SB car with manifolds. I am looking to upgrade to headers and 2.5 exhaust.
Can I buy headers and match it up with a OE 2.5" dual exhaust setup for a BB ?
Basically I would be running an OE BB exhaust pipe setup from the tail pipes up to the collectors. Hoping I can just cut off the OE setup I found on Craigslist and hook it into the header collectors.
It will work. You will most likely need to custom fit the pipes. The middle pipes and mufflers will be the same. Jegs sells a pair of collector offset adapter pipes (part number 500-18806, made by Hedman) that may work for you as well.
