Key buzzer
Old Nov 26, 2011 | 11:42 PM
Mike 73's Avatar
Mike 73
1st Gear
Default Key buzzer
What causes a key buzzer to continually sound with or without the key in ignition when door is open?
Old Nov 27, 2011 | 06:48 AM
1986coupe's Avatar
1986coupe
You will have to open up the steering column to see why the switch isn't working properly.
Old Nov 27, 2011 | 08:32 AM
kilowatt's Avatar
kilowatt
my 70 was doing that. i sprayed some wd-40 in the lock and worked the key in and out and it stopped mine. the tumblers get stuck and need to be freed up.
To Key buzzer
