Neutral Safety Switch Help..Pics?
Old Nov 28, 2011 | 08:57 PM
mikem350's Avatar
mikem350
Default Neutral Safety Switch Help..Pics?
Have a 77 auto, TH350, and there is no mechanical connection between the shifter and the switch..no pin, bracket, nothing..switch is there, but does not move
Can't find a pic in the AIM or parts catalogs...
Any help (pictures!!!) appreciated
Old Nov 29, 2011 | 04:47 AM
Ralphbf's Avatar
Ralphbf
Do you have voltage going to one of the purple wires?
They are hooked to a 5 amp. fuse.
That would be a good place to start.
Ralph
Old Nov 29, 2011 | 12:30 PM
mikem350's Avatar
mikem350
The car starts ok...the switch is ALWAYS in park..
I now see whats missing..the pin from the shifter to the switch.
What part is that...or can a another pin be fitted?
Old Nov 29, 2011 | 03:42 PM
mikem350's Avatar
mikem350
ttt
Old Nov 29, 2011 | 08:32 PM
Ralphbf's Avatar
Ralphbf
So it starts in any gear?
Ralph
Old Nov 29, 2011 | 09:09 PM
mikem350's Avatar
mikem350
Yes starts in any gear...the SWITCH thinks its in Park
Sooooo..how do you fix the missing pin??
Old Nov 30, 2011 | 03:06 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Go to this link here...It is very helpful. You don't fix the missing pin...you place the WHOLE switch.
http://www.zip-corvette.com/ProductD...R-SR&CTitle=&#
Old Dec 1, 2011 | 04:04 AM
dembo's Avatar
dembo
Hi, don't have a actual pic but found a aim page (PIN A) and detail actuating tang.
I think it's a regular slotted spring pin, vendors don't seem to carry them but you should be able to find it in hardware stores?
Nick
Old Dec 1, 2011 | 10:36 AM
mark6669's Avatar
mark6669
there should be a hole in side of shifter you just need a roll pin 2mm x 15 mm from any hardware store
Mark
Old Dec 2, 2011 | 12:05 AM
vetteguy75's Avatar
vetteguy75
Default Very very important!~!!!
Compare the OEM wires and their placement to the aftermarket plug and make sure they are the same.
The wires on the NEW neutral safety switch, on the backup lights plug (pink & green wires), are BACKWARDS from the OEM switch. They're manufactured from M&H Electric Fabricators and I think they have a bad batch. I know because I purchased 2 from ZIP and 1 from Ecklers and they all do the same thing...my backup lights stayed on the whole time the engine was running . WRONG!!!!!! When I compared it to the OEM switch to the aftermarket switch, that's when I saw they were BACKWARDS!!!! I swapped the wires, the switch works like the OEM!!! And it still works!
I called M&H Electric Fabricators on this and told them what I encountered....
FYI
To Neutral Safety Switch Help..Pics?
