How do you remove the trim from the upper door?
Old May 7, 2002 | 11:55 PM
dewayne4
Default How do you remove the trim from the upper door?
On a 79, how do you remove the chrome trim from the glass on the driver and passenger side doors? :confused:
Old May 8, 2002 | 12:05 AM
Pete79L82's Avatar
Pete79L82
Default Re: How do you remove the trim from the upper door? (dewayne4)
If you are refering to the strip at the top of the door it is heald on with a couple of screws and push clips. You have to remove the interior trim panel and loosen the window stops so the window will go all the way down. Remove the screws (3 or 4?) then gently pry the trim away from the door panel. There are two parts there. One is the rubber weatherstrip with a small chrome bead on it and the other is a seperate chrome molding.
[Modified by Pete79L82, 10:06 PM 5/7/2002]
Old May 8, 2002 | 12:20 AM
dewayne4
Default Re: How do you remove the trim from the upper door? (Pete79L82)
I will check it out tomorrow. Thanks :cheers:
To How do you remove the trim from the upper door?
