input on this shifter kit??
Old Dec 2, 2011 | 09:11 PM
McVette's Avatar
McVette
Default input on this shifter kit??
Hey guys i would like to know if anyone knows anything about this kit.....i downloaded the instructions and it doesnt look like it would be too difficult to install if it is worth a crap........here is link and thanks for replyinghttp://www.bmracing.com/PRODUCTS/Bui...H-350-and-M38#
Old Dec 2, 2011 | 09:16 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
I used the "TransGo" and it was simple and easy. Works Great. Have had it in the car now a year.
Old Dec 2, 2011 | 10:13 PM
pricesgarage's Avatar
pricesgarage
i have a trans shop in wva for a home mechanic the b and m kit and fairbanks kits are the easiest to install it will bark tires and hit hard i install a transgo kit in all th 350 rebuilds it firms up the shifts rasies the 2-3 shift point not agressive if calibrated for normal uses and rasies line psi
when doing the band m kit i recomend removing the 1 -2 accumulator spring on the side
and the 2-3 accumator in the valve body dill the feed holes to hd specs in the plate and remove the modulator spring put all the check ***** in while your doing this get a adjustable modulator turn the screw all the way in and back it off 1 turn if its a high milage unit id wait till you do a rebuild the increaced clutch apply on worn clutches can cause some issues
To input on this shifter kit??
