Currently my enging is picking up the water temp @ the head. I am going to install a manual and was wondering where would be the best place to place the bulb. Intake or the heads.
Same question on the Oil. Currenty is tapped at the Oil Filter. Any difference between that location vs. the back of the block location?
Thanks!
Factory placement of the temp. sender is out of the way & works fine.
I put the oil temp. sender at oil filter & oil pressure sender at top of block. Later found out the factory agreed w/ me or I agreed w/ the factory.
