Left Headlight opens before Right side
Old Dec 3, 2011 | 11:01 PM
Mark Hawkins's Avatar
Mark Hawkins
Default Left Headlight opens before Right side
Hey Guys. I just watched a commercial for the 81. What I noticed was in the add, when they turned on the headlights, they both went up at the same time and lowered at the same time. Mine do not. The leftside will open first then the rightside will open. Rightside closes first and then the leftside. I must have a problem, however I'm not sure where or how to started looking to see if I have a problem. Any leads will be grateful.
Thanks.
Old Dec 3, 2011 | 11:17 PM
Roughrider's Avatar
Roughrider
That's not uncommon. About the only requirement the feds gave for concealed headlights was that they had to be open within a specified amount of time...don't know what that figure was, though.
For a commercial you can bet Chevrolet made sure they opened together...even if they had someone under the hood turning a crank that opened them.
Old Dec 4, 2011 | 02:13 PM
Mark Hawkins
Thanks Roughrider.
Mark
Old Dec 4, 2011 | 02:55 PM
Mike Ward's Avatar
Mike Ward
The lights raised and lowered simultaneously and virtually instantaneously when the cars were new. You could also leave the car for a few hours/overnight and the lights would still raise without starting the engine.
Old Dec 4, 2011 | 06:00 PM
Peterbuilt's Avatar
Peterbuilt
A lot of times the seal in the actuator is the problem
To test the actuators go here:
http://www.corvette-101.com/vacuum.htm#actuator
The relays can be the problem too.
To test them go here:
http://www.corvette-101.com/vacuum.htm#relay
There is a "Sticky" up top in you want more information.
Old Dec 4, 2011 | 06:40 PM
McVette's Avatar
McVette
Mark mine do the same.....about 1 second delay......but not gona worry about mine alot right now.just posting so u know alot others prob do the same
Old Dec 4, 2011 | 07:21 PM
Paul L's Avatar
Paul L
One second? Bang on and leave well enough alone.
Old Dec 4, 2011 | 07:32 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Old Dec 4, 2011 | 07:52 PM
McVette's Avatar
McVette
ohh trust me i will not touch it......lol
Old Dec 5, 2011 | 06:28 PM
VetteHalen's Avatar
VetteHalen
i have the same deal with my headlights... right comes on after the left.
the one issue with mine is that the right headlight isn't fully open (the bottom edge is slightly lower than the top of the opening on the bumper). this causes the lamp to shake more than the left, especially on the bumpier 'truck lane' on the freeway.
when i last poked my head around under there i noticed that the rod connected to the actuator wasn't fully extended (left side was) and i haven't gone back in there to figure out how to make it extend.
if it makes you feel a little better, do the "cheat" i sometimes do: i pull the manual override switch to make the housings come up, -then- i pull the headlight switch to turn on the lamps...
Old Dec 5, 2011 | 10:13 PM
Mark Hawkins
Thanks Pete. Good Info.
Old Dec 5, 2011 | 10:15 PM
Mark Hawkins
Thanks, if you haven't seen it on You Tube, the 1981 Corvette commercial shows the head lights. Mine too are like yours. At least it sounds fairly typical. I'll do the test that Pete supplied. Thanks again.
Old Dec 6, 2011 | 12:23 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
My 68 does it too
Glad its expected after 43 years.
I get a left than a bang and the right appears.
Facinates the HID driving lights BMW types
It's all part of that great GM feeling we get each time we drive.
Merry Christmas from thee Marshal
Old Dec 6, 2011 | 03:10 PM
81pilot's Avatar
81pilot
Thanks.
I sprayed the actuators and filters with WD 40 and they are alomost equal again on mine. just a quick pop-pop.
Old Dec 7, 2011 | 04:54 AM
VetteHalen's Avatar
VetteHalen
ahem. cough.
...i'll be right back!
Old Dec 7, 2011 | 10:23 AM
63split63's Avatar
63split63
I use "Fluid Film" on linkages and pivot points . The stuff is great . Most don't buy it because it is expensive . WD40 is pretty thin and more like a penatrant than a lube so it dosent last as long.
JMO Bill
Old Dec 8, 2011 | 04:13 PM
Duane4238's Avatar
Duane4238
Gee, all these years I was under the impression that the lights that open at the same time are the ambidextrous model. If your right headlight pops up first, then you must have gotten one of the rare right-handed Vettes. If you ever sell on E-Bay, you can list it as rare and ask $10,000 over book price.
Duane
To Left Headlight opens before Right side
Old Dec 8, 2011 | 04:57 PM
Mark Hawkins
Duane
too funny Duane.
Old Dec 8, 2011 | 06:18 PM
rdroe's Avatar
rdroe
DC Area Events Coordinator
Ha! I have the left handed model as well. My 82 does the same. Going to tear into them as the 3rd project this winter. Going in deep!
Old Dec 9, 2011 | 10:42 AM
MrJlr's Avatar
MrJlr
Be lucky they pop up at all !
Mine pop up durring WOT.....
