Wheel and tire size
my 71 project is almost done. Im still waiting on the body guys to paint my new L-88 hood and ill get a set of wheel.
First the car will be a serious street performance car. (406ci with over 580 hp at the crank)
Before i order the wheel i would like to know what size of wheel / tire should i buy.
Im looking for torq thrust wheel or the torq thrust D. (what is the difference between both beside color seem to be bit different?)
I want to put 15x4.5 or 15x5 at the front and 15" x 8" +0 or 15" x 8.5"-25 at the back.
What should i buy the 8 or 8.5. I will be running stock trailing arm and i dont want the tire to stick out of the fender.
For the tire i think 255/60/15 are pretty standard. Can i go bigger than that?
thanks!
In 15" the 255/60x15 is the biggest you can go without mods. I have American Racing 200s at 8.5", not sure about offset.
I already instaled 90/10 shock up front , 50/50 at the back. Removed front sway bar...
I dont want 17 because i want a "sleeper" look. Beside the hood and wheel i want to keep the car look the more original possible.
Also i always prefered meaty rubber than big wheel and low profile tire.
Why would you want to remove the front sway bar? That car will be VERY unstable and SCARY to drive at any highway speed. If you want to reduce the friction in the suspension, mount the bar to the frame in poly, and shim the brackets so the bar has a tiny, tiny amount of play. That could work. But don't remove it.
The Torq thrust "D" is designed to clear a Disc brake caliper. That's the one you want.
For the sway bar, my friend/mechanic who work on the car is a specialist in performance vet he got many year of experience with them, that him that has recommend me to do that.
Stock Vette wheels were 15x8 with 4" bs.
The 255/60R15 are the largest "guaranteed to fit with no mods" size, but a 275/60 will normally fit with no trouble.
If you run a good drag radial, then the 255's will be plenty big enough to hook the engine your using.
The front wheels do all of the steering, most of the braking, and carry half the weight of the car. Why would you put smaller tires there?
IMHO, unless you are putting the car on a trailer, driving it 1/4 mile down the track, and then trailering it home, it's a bad idea.
