Right spark plug gap made a big difference
Old Dec 8, 2011 | 05:09 PM
Rick_V's Avatar
Rick_V
Default Right spark plug gap made a big difference
I finally got around to replacing the plugs over the weekend. When I pulled the first plug it didn't look like it was supposed to and electrode looked like new but, when I checked the gap it was only 0.025. I replaced all the plugs with the new ones gapped at 0.035. All the old plugs had the same appearance and the same 0.025 gap. WOW what a difference in throttle response. I got the car in July and had chased a lot of things trying to figure out why throttle response was so crappy. Car as 270 cam in it and it has came to life with the new plugs (and correct gap). I plan to experiment with wider gaps to see if I can improve on it.
Old Dec 8, 2011 | 07:30 PM
Paul L's Avatar
Paul L
You seem to have a 1979. Go with the GM/HEI-recommended 0.045". The 0.035" is for points cars.
Old Dec 8, 2011 | 08:51 PM
Rick_V's Avatar
Rick_V
OK, still trying to figure out why the PO had em gapped at 0.025.
Old Dec 8, 2011 | 08:57 PM
pws69's Avatar
pws69
Don't spend too much time - they were just wrong and you will just be going backwards.
Nice job!
Old Dec 8, 2011 | 10:32 PM
jimboscarbs's Avatar
jimboscarbs
Default Plug Gap
Most SBC Dyno best with a healthy ignition from .032-.038 gap
Old Dec 8, 2011 | 10:40 PM
scottyp99's Avatar
scottyp99
Some people just screw 'em in there without checking the gap, .025" might just be what they were at out of the box. Don't worry about it, just get the gap set correctly. Like paul 74 says, HEI is .045", give it a try, let us know how it works out. Not sure what kind of experience level you are at, but if you are a novice, it's called super tuning, and it can sometimes make a noticeable difference, as you know. Next step is to optimize timing, if you haven't already.
http://forums.corvetteforum.com/c3-t...long-post.html
See ya!
Old Dec 9, 2011 | 07:43 AM
Rick_V's Avatar
Rick_V
See ya!
I am not a Novice but, not exactly a Pro I am somewhere in between. I had pretty much tuned it to optimum timing, jets etc. except for the plugs got a little lazy an didn't want to mess with them. I actually took the car out to Gainesville Raceway about a month ago for a test and tune. I just wanted to see what it would run. I only made one pass. It ran 13.55@101 mph with street tires and I lost a lot of first gear acceleration due to tire spin had a 2.03 60'.
Old Dec 9, 2011 | 03:35 PM
scottyp99's Avatar
scottyp99
Hmmmm, you sound like someone who should have known better than to just take the plugs for granted. Shame!!! Ahhh, well, we live and learn, right?
Scott
To Right spark plug gap made a big difference
