crate motors
Old May 8, 2002 | 05:40 PM
Corvettelvr73's Avatar
Corvettelvr73
Default crate motors
I am considering a new crate motor to replace a L-48. What motor is good for everyday driving and something that will push me back in the seat more than the old L-48. Also im considering a new transmission what do you guys reccomend and how much am I looking at to install a new motor? How hard is it since the old block is a two-bolt and the new one a four-bolt? Thanks in advance.
Old May 8, 2002 | 05:48 PM
Zack Wenning's Avatar
Zack Wenning
Default Re: crate motors (Corvettelvr73)
Sounds like you'd like a new GM ZZ4 crate engine. 355hp 405 torque would put ya back in your seat plus it comes with a good warranty. They run about $3500 for the motor, I've heard installation runs about $500. Is there something wrong with your trans?
Do a search for ZZ4 in the archives to find much more info.
Old May 8, 2002 | 05:50 PM
kgraumann's Avatar
kgraumann
ZZ4 all the way! It puts me back in the seat when I take off. Not bad on MPG also. :yesnod: :yesnod: :yesnod: :yesnod:
Old May 8, 2002 | 05:54 PM
Michael Tucker's Avatar
Michael Tucker
zz4 all the way :cool:
and i bet u and a friend could do it and save the money i did it so let me know if u have any questions
mike
Old May 9, 2002 | 01:29 AM
Cruzmeisters's Avatar
Cruzmeisters
Default Re: crate motors (Michael Tucker)
http://www.paceparts.com for info on various crates available
Cruz
Old May 9, 2002 | 03:09 AM
VetteNut72's Avatar
VetteNut72
Ditto everyone else - ZZ4 is your best choice.
Old May 9, 2002 | 03:50 AM
Ben Taylor's Avatar
Ben Taylor
A lot of people think of motor mounts when they hear two-bolt, and four-bolt main. This term refers to how many bolts hold on the crankshaft main bearing caps, most engines use two for each cap, higher performance engines use four. This is all inside the engine, so it shouldn't effect your installation at all.
Every Chevy V8 has two motor mounts, so that shouldn't be a problem.
Old May 9, 2002 | 04:04 AM
Darkness's Avatar
Darkness
502 RAM JET:lol:
Yeah baby!!!
Naaa, too much for the drive train....
ZZ4 is the best all around engine for what your looking for.
Good luck
Paul
Old May 9, 2002 | 09:23 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
I put a ZZ4 (385 FB) with a hot cam in my '70, and let me tell you that will put you back in your seat.. Salle Chevrolet in Milton Freewater OR has the best deal I have seen.
Old May 10, 2002 | 12:26 AM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Default Re: crate motors (Zack Wenning)
just a bit curious about these motors. do they use the same exhaust manifolds? what about original smog equip etc...
Old May 10, 2002 | 12:31 AM
Cruzmeisters
Default Re: crate motors (eleven79)
My '62 FI exhaust manifolds hooked right up to the ZZ4 :yesnod: :yesnod:
Cruz
Old May 10, 2002 | 12:34 AM
Justin79-L-82's Avatar
Justin79-L-82
Default Re: crate motors (Cruzmeisters)
Get the new 708! 880 horsepower stock.. too bad they are like 30 grand hahahaha
Old May 10, 2002 | 12:52 AM
Noel Carboni's Avatar
Noel Carboni
Check this:
http://www.speedomotive.com/Assembled%20Engines.htm
http://www.speedomotive.com/chevy_47...ster_415_m.htm
-Noel
Old May 10, 2002 | 01:48 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: crate motors (Noel Carboni)
check this out --- http://temp.corvetteforum.net/c3/bseery/zz41.htm
Old May 10, 2002 | 07:28 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: crate motors (BSeery)
A friend just put a Ramjet 350 into his 60 Corvette. He loves it, saying it's so much better than the 327 he had in it in every way. He also says it was an easy install even with the FI ;) .
Old May 10, 2002 | 11:09 AM
73ragtop's Avatar
73ragtop
Default Re: crate motors (SmokedTires)
Please let us know more about this swap. Many of us have considered the RamJet 350 for a swap, but can't get solid info about whether or not it will fit under a stock small block hood. I haven't found anyone who actually has made this swap, and though I'm sure the clearance in a 60 Vette is different, it would sure be nice to hear about the details of the swap. Pictures would be great too. Thanks.
Eddie
Old May 10, 2002 | 11:17 AM
SmokedTires
St. Jude Donor '05
Default Re: crate motors (73ragtop)
I'll see what I can do for height measurements & snap some pics this weekend. I fit under his stock hood fine :yesnod: . He had to install an electric fuel pump for the FI, but there was only 1 positive wire that went thru the firewall, all the rest were under the hood :D .
Old May 10, 2002 | 11:38 AM
Noel Carboni
While I don't have a RamJet, I did fit a TPI under my C3 hood. I had to carve the 1982's inner hood passage wall out, but it fits. Figuring out where to put an air cleaner is a bit of a challenge.
Here's detailed info on my TPI swap. Different hardware, but the concepts apply.
http://home.att.net/~ncarboni/NCtpi.html
-Noel
Old May 10, 2002 | 02:39 PM
chrisgable's Avatar
chrisgable
If you are worried about cost the GM Goodwrench motor looks pretty good at about 1,200.00. Its about 220 hp stock and CHP or one of those mags did a 450 hp builup on on one of these. I guess it depends on budget and how much know how you have.
To crate motors
