81 Corvette Engine Build
Old Dec 10, 2011 | 10:03 PM
c3sleeper's Avatar
c3sleeper
Default 81 Corvette Engine Build
Hey guys i've got an 1981 Vette thats pretty much stock so far in everything but the exhaust which has been upgraded to the standard Magnaflow headers, pipes, and mufflers. Im looking to pull around 350-400 hp out of it. What would I need to do to get this kind of power and what would it cost me approximately.
Old Dec 11, 2011 | 01:18 AM
bluedawg's Avatar
bluedawg
You can buy a top end kit from summit or scrogin dickey to build 350 or 400 pretty easily. Good luck.
Old Dec 11, 2011 | 10:06 PM
383corvette's Avatar
383corvette
Go with the top end kit for now.
My uncles 81 with an edelbrock intake, holley 650, headers and flowmasters put down an "astounding" 170 hp.. To achieve 350-400 you should go with heads/cam and a bigger carb setup and see how that does.
Your looking at spending AT LEAST a couple grand for a good top end kit. I know edelbrocks runs around $2k a little lower or higher depending on setup. But with all cars you cant just focus on the engine, after you get close to that 350-400 it would be a good idea to get a stall and shift kit, then all the way out back switch to some lower gears. My uncle just spent around 8 grand on a 400 engine and hughes performance transmission. I spent $5k on my 383 stroker. Horsepower is gonna cost you money, it just depends on how much your willing to dish out..
Old Dec 12, 2011 | 02:09 AM
c3sleeper's Avatar
c3sleeper
Im looking to go with a new set of heads, roller lifters, roller cam, air gap intake, 800 cfm Edelbrock, and 383 rotating assembly. Im wanting to stay with the 4 speed muncy and put in a clutch with stiffer springs. The reason for this being i'm wanting to keep the stock wheel and tire combo and this motor would be revving to around 6000 that is as fast as one can feel relatively stable with the relatively large sidewall. In addition i'm pulling off the stock fan and installing a dual electric fan kit to keep as much of the horsepower going to the rear wheels as possible. In addition i'm looking at possible having it internally balanced at a local engine shop. Any thoughts on this general plan?
Old Dec 12, 2011 | 03:02 AM
383corvette
That setup should have you easily around 400hp depending on cam and heads of course. Depending on how good your block is now depends on if its easier to go with a fresh block or keep yours. You never know what your gonna run into until you pull it out. I had to get a new block for mine and start from scratch. Do plan to get it bored .030 over if 383 is your plan. You'd be good on the exhaust side since you've got a good pair of headers. You'll also be looking at going ahead and upgrading your distributor with the added horsepower as well as your wires. You can easily get into a few grand for all this. But I couldn't be happier with my 383
Old Dec 12, 2011 | 03:20 AM
c3sleeper's Avatar
c3sleeper
The block is the original with 59,000 easy miles on it. It doesn't use hardly any oil. The plug wires were also replaced when the headers were installed and high performance wires and plug ends were installed. The only issue i've ever really had with the car is that right now the alignment on the rear wheels is off. Instead of being around 0 degrees they are very obvious to the eye off in that one could eyeball them at around 3-5 degrees off. That sure makes for an interesting driving experience haha. Would I additionally need to upgrade the fuel pump to account for obvious increased need for pressure when the 800 opens up?
Old Dec 12, 2011 | 03:37 AM
383corvette
http://www.summitracing.com/parts/EDL-1721/
This is the pump I use but I know of others who stay with the stock pump and it run just fine.. I've heard that the stock ones are capable of handling up to 375hp but not sure how true that statement is. The only reason I went ahead and replaced it was to be on the safe side.. I'd say you have a hell of block if its at 59k! With that you should be able to stick with your block and save some $$ which is always good. I know my uncles 81 gears sat at 2.92 if Im correct? With 400hp you should look into lower gears while your at it if you wanna be able to handle the power.
Old Dec 12, 2011 | 04:27 PM
c3sleeper's Avatar
c3sleeper
The gearing was actually a 2.72:1 in the manuals which is what I've got.
Old Dec 13, 2011 | 07:54 AM
jackson's Avatar
jackson
QuadraJet carb more than enough for 400hp
best value ... Delivered to your USA door for about $3200 ... all this
http://www.yearone.com/Serverfiles/p...archid=6446007
* Horsepower: 400+
* Torque: 400+ ft/lbs
* Compression ratio: 9.7:1
* Dyno-tested: Yes, includes 8" balancer & 14" flexplate
* Dyno sheet: Included with engine's output
* Vacuum produced: 12hg @ 800RPM
* Recommended fuel: 92 octane
* Max recommended RPM- 5800
* Block: Seasoned 4-bolt iron
* Crankshaft: OE cast iron
* Pistons: Hypereutectic
* Connecting rods: Powdered metal
* Camshaft- Hydraulic roller with YearOne proprietary specifcations
* Rocker arms: Stamped steel 1.6:1 ratio
* Cylinder heads: Ported Dart Iron Vortec
* Valves: Stainless steel 2.02 int/1.60 exh
* Valve springs: Heavy duty
* Bore x Stroke: 4.04" x 3.48"
* Intake manifold: Dual-plane aluminum
* Oil pan, timing cover, valve covers included
* Engine fasteners: High tensile strength
* Warranty: 12 mth/12,000 mi
Old Dec 13, 2011 | 08:44 AM
qwank's Avatar
qwank
Gears should be your first upgrade on an '81 before you even touch the engine. Then the crate motor listed above with the stock carb (if its still there) would be the best bang for the buck. Nothing wrong with doing a 383 like you plan though. Just don't use an Edelbrock carb.
Old Dec 15, 2011 | 12:35 AM
c3sleeper's Avatar
c3sleeper
What's the issue with the gears? Dana 44 with 2.72 runs approximately 150 at 6000. The Goodyear Eagle GT II I'm running aren't speed rated so it won't be driven any faster than that and I'm looking to stay with the original wheel and tire for now. If its the fuel mileage argument my personal opinion is the if you can't afford the gas you can't afford the car haha
Old Dec 15, 2011 | 07:10 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
For me, it isn't the top end but how it feels around town and on the freeway. Changing to a higher numerical rear gear (my '80 has a 3.55 from the factory) gives a rush of acceleration when I need it or when I want to show off a little. With a hotter cam you'll need a better gear for torque multiplication if for no other reason.
Old Dec 17, 2011 | 12:50 PM
c3sleeper's Avatar
c3sleeper
Default $$$
It looks like around $8,000 is going to my budget. I live in a pretty small town and one of my buddies works for a racing engine builder in a bigger town nearby. He has access to balancing equipment and everything but he does all the work in his own shop on the side for projects like this. Since I'm planning on over 400 hp a new clutch will be needed. Any suggestions?
Old Dec 18, 2011 | 06:34 AM
LannyL81's Avatar
LannyL81
Getting the rotating mass balanced is a must if you are planning on turning 6k RPMs. The balancer, crank, rods, pistons, flywheel, clutch...all need to be balanced.
Old Dec 18, 2011 | 03:02 PM
texasbaehr's Avatar
texasbaehr
Unless you are concerned with keeping the numbers matching block, your least cost would be a crate motor then trying to rebuild the stock one. There are a lot of alternatives out there for crate motors under 5K that will get you 350 - 400HP. IF you have an automatic youll need to investsome money or replace that to handle the HP.
To 81 Corvette Engine Build
