L 82 and L 48
Old May 8, 2002 | 11:13 PM
Mighty Mouse's Avatar
Mighty Mouse
Default L 82 and L 48
What is the difference between the L 82 and the L 48 that gives the L 82 the extra ponies? :D
Old May 8, 2002 | 11:18 PM
Ganey's Avatar
Ganey
Default Re: L 82 and L 48 (Mighty Mouse)
Mainly more cam & larger valves. A little more c/r as well.
EarnIt's Avatar
EarnIt
The L82 has a bigger cam, better heads, and I believe a better intake manifold.
Old May 8, 2002 | 11:44 PM
73-454's Avatar
73-454
Default Re: L 82 and L 48 (Ganey)
L82 is a de-tuned 1970 350/350 engine just lower compression and more polution related stuff. As a matter of fact the Goodwrench crate engine is based on a 4 bolt maine L82 engine and the good news is you can buy it for less then $1400 with a 3 year warranty.
Old May 8, 2002 | 11:47 PM
Tom73's Avatar
Tom73
Cam and compression. Plus a little help from larger valves. The big plus for the L82 is a stronger lower end with forged parts and 4-bolt mains. And depending upon year, the L82 had 2 1/2 inch exhaust vs the L48 2 inch exhaust.
tom...
Old May 9, 2002 | 12:53 PM
vettedan's Avatar
vettedan
Default Re: L 82 and L 48 (Tom73)
Tom73-Dittos to all above. '78 L82's and up came with dual snorkel air filter.
Dan
Old May 9, 2002 | 01:06 PM
Fevre's Avatar
Fevre
Default Re: L 82 and L 48 (73-454)
But cast not forged crank, cast pistons and small cam. Got one and it is worth the money. If I keep it, I will put the aluminum heads on and it should be a nice little engine with about 330 horse.
Old May 10, 2002 | 02:46 AM
KenKathy's Avatar
KenKathy
Cruising
I have a 74 w/ L82 and I would like more technical data, 250hp vs 195 for the base 350, sounds like a lot to me, any ideas to find more data, anyone? :confused:
Old May 10, 2002 | 09:27 AM
Tom73's Avatar
Tom73
Default Re: L 82 and L 48 (KenKathy)
Ken,
The 74 is basicly the same as the 73, so take a look at The '73 Spot for details. Here is the direct like to the specs page: http://www.corvetteforum.net/c3/vette73/compair.htm
tom...
Old May 10, 2002 | 03:26 PM
chrisgable's Avatar
chrisgable
thay have a higher redline also.
To L 82 and L 48
