request from Germany : tele steering column
Old Dec 14, 2011 | 07:32 AM
GT-Ralle's Avatar
GT-Ralle
Default request from Germany : tele steering column
Hello together,
I'm from Germany, got 3 month ago my 68 conv. with tele steering column (N36) .
The German Corvette Forum couldn’t help me with the following problem.
The steering column is loose 2cm = 0,7874 inch up and down
I understand I can adjust this with the Center Star bolt
Open = free way up and down
Close = should be fixed, but I have still this 0,7874 inch up and down
My technical English vocabulary is very limited, means if you like to give me answer, possible to this with simple words or with pictures
What can I do to eliminate this 2 cm (0,7874 inch) up and down in bolted position
would be great to get some feedback.
Ralf
Old Dec 14, 2011 | 08:17 AM
Jim Shea's Avatar
Jim Shea
Ralph,
Here is a blowup of a typical 1967-68 Corvette telescoping steering column.
My first thought would be that the three screws (#3) that attach the turn signal switch #4, the Cover #6 and the Upper Bearing Housing #5 may have loosened.
If that is the case, you will have to remove the steering wheel and use a puller to remove the steering wheel hub in order to reach those screws.
You will note in the above picture that there is a star screw #4 that tightens against a rod inside the steering column. Tightening and loosening the screw either locks the telescope feature or allows it to telescope.
When you use a puller to remove the steering wheel hub, you should protect the threaded end of the steering column steering shaft where the star screw threads are exposed. A metal washer would be sufficient. Otherwise you might damage the female threads in the steering shaft with the puller.
Next and the more severe problem would be that the upper bearing (part of #5 in the first blowup picture) has gone bad. If that is the case you will need to remove the bearing housing from the steering column. You will be able to quickly note if the bearing is missing *****, loose, full of metal particles etc.
You will find that the upper bearing is a press fit into the die cast housing and a thin lip on the housing was spun over to retain the bearing into the housing. You will find that a replacement bearing housing assembly (with bearing) is very rare, and very expensive. You would be best served to try and just replace the bearing into your original housing. Bearings are still available. If you find that this is the real problem, we can address replacement bearings, etc with a further posting.
Good luck,
Jim
Old Dec 14, 2011 | 08:35 AM
GT-Ralle's Avatar
GT-Ralle
Thanks Jim
this are the steps I have done
[IMG]
Old Dec 14, 2011 | 09:24 AM
GT-Ralle's Avatar
GT-Ralle
"Next and the more severe problem would be that the upper bearing (part of #5 in the first blowup picture) has gone bad. If that is the case you will need to remove the bearing housing from the steering column. You will be able to quickly note if the bearing is missing *****, loose, full of metal particles etc.
You will find that the upper bearing is a press fit into the die cast housing and a thin lip on the housing was spun over to retain the bearing into the housing. You will find that a replacement bearing housing assembly (with bearing) is very rare, and very expensive. You would be best served to try and just replace the bearing into your original housing. Bearings are still available. If you find that this is the real problem, we can address replacement bearings, etc with a further posting. "
possible to show me on hand of a real pricture where part 5 is located.
thanks
Ralf
Old Dec 14, 2011 | 09:38 AM
Jim Shea's Avatar
Jim Shea
Now you can remove the steering wheel (six screws). Then the steering hub nut. (Be careful that you don't damage the horn contact plunger at 10 o'clock.)
With the hub nut removed you now have to install the puller to remove the hub from the steering shaft. There are two threaded holes in the hub (I believe from your picture they are located at 1 and 7 o'clock either side of the hub nut.) Do not even think about hammering on the hub to get it off instead of using a puller!
Once the hub is removed you will be able to remove the cancelling cam spring #12 and the cancelling cam #16. You will now have the three screws exposed that hold the turn signal switch, bearing housing, and cover. See if the three screws are loose. Hopefully, this is your problem!
Part #5 will be right under the turn signal switch.
Jim
Old Dec 14, 2011 | 09:45 AM
GT-Ralle's Avatar
GT-Ralle
thanks, will follow step by step and keep you informed.
Ralf
Old Dec 14, 2011 | 10:10 AM
Jim Shea's Avatar
Jim Shea
Ralf,
For some reason I couldn't reply to your further private message about a steering wheel puller.
The third picture above labeled "Typical Steering Wheel Puller". A puller is a simple bar with a large bolt that threads through the center. Smaller bolts on either side of the larger center bolt screw into two tapped holes in the hub.
Make sure that everything is square. If you **** the puller bar, you can break the smaller bolts that are threaded into the hub.
It may take quite a bit of force but the puller should loosen the hub from the tapered hub and steering shaft.
Jim
Old Dec 14, 2011 | 10:19 AM
GT-Ralle's Avatar
GT-Ralle
in that case, before I damage something with my two left hands, my brother (former car mechanic) has to assist me
Thanks a lot for you patient - will take some time but for sure will come back with the result.
Ralf
Old Dec 14, 2011 | 11:46 AM
Jim Shea's Avatar
Jim Shea
Ralf,
Once the puller breaks the hub from the steering shaft taper, the hub will come right off. The reason you don't want to hammer on the hub to break the taper lock is that you can/will damage the steering shaft bearings with the hammering.
Jim
Old Dec 14, 2011 | 11:49 AM
wolflt1's Avatar
wolflt1
i also had a loose in/out steering column.
today i carefully pried off the horn cap, undid the three long screws #2 that hold the horn contact plate. removed the plate and the spacer, then was able to access the star screw.
under the lock **** #5 were three thin shims.
took out the two screws #3 that hold lock **** and set the star screw. tightened the star screw clockwise a wee bit and then turned the lock **** completely to the right at the same time aligning the lock **** with the star screw and screwed in the two screws #3 opposite each other.
everything is tight now with the lock **** turned to the right and the loose in/out movement of the column is gone.
thanks to the jim shea docs
'70 vette
Old Dec 14, 2011 | 12:03 PM
Jim Shea's Avatar
Jim Shea
Now with the star screw tightened and the upper steering shaft not telescoping any longer, is your looseness problem solved?
Jim
Old Dec 14, 2011 | 01:19 PM
wolflt1's Avatar
wolflt1
Jim
now i can push in or pull out the column when the lock ****/lever is turned fully left and tighten it in any position. so i supposed my problem is solved.
thanks
wolf
Old Dec 14, 2011 | 03:03 PM
Günther-C3's Avatar
Günther-C3
deleted
Günther
Old Dec 14, 2011 | 03:04 PM
Günther-C3's Avatar
Günther-C3
Sorry, now I can see the pics......
Günther
Old Apr 14, 2012 | 08:53 AM
GT-Ralle's Avatar
GT-Ralle
Hello JIM,
took quiet a long time but we had a very strong winter. In the garage my Vette was waiting at about - 5 to - 15°C, was too cold to do something.
Finally when weather got better I started to follow you instructions - 3 times - but could not find the problem.
NOW FINALLY TODAY checked again with my brother and it was that simple just a loose screw ( steering box)
it's done and my wife is as well happy.
Regards
Ralf
Old Apr 16, 2012 | 08:39 PM
VCuomo's Avatar
VCuomo
The most important thing, of course, is that your wife is happy!
To request from Germany : tele steering column
