Clutch Kit
Old Dec 17, 2011 | 02:13 PM
newbie2vette's Avatar
newbie2vette
Default Clutch Kit
My engine is finally ready to be put back in, I decided to install a new clutch. But, everytime I call for clutch the size of the disk I am being told is 10 1/2". I measured the one I removed it is closer to 11", one guy looked up the size for the Big block. It is 10 15/16" which is closer to 11".
I was told by the previous owner a differenct clutch was installed on this car (high performance) version. So, can I go with the big block clutch kit that contain the 10 15/16" disk? thank you.
Old Dec 17, 2011 | 03:13 PM
Red 69's Avatar
Red 69
Sure, as long as the clutch slips over the splines of your trans shaft. Also, be sure you start with a flywheel that has been resurfaced. I am using an 11 inch clutch disk on my small block engine.
Old Dec 18, 2011 | 02:27 PM
newbie2vette
Thank you! I went with the High Performance version which include the 11" X 26 spine disk. Yes, the same guy who duild the motor turned it and balanced it with all the internal part of the engine.
Old Dec 18, 2011 | 09:08 PM
gcusmano74's Avatar
gcusmano74
Be careful about your clutch selection. You must be realistic about the available engine torque and your use of the car. Put in a race type clutch that will hold 700 lb ft, and you won't be happy if you need to drive that car in stop and go traffic.
To Clutch Kit
