HEI Distributor Part Question
Old Dec 17, 2011 | 07:13 PM
LannyL81's Avatar
LannyL81
Default HEI Distributor Part Question
What is the name for the part that goes between the coil and the rotor for the high voltage path? This is the piece that touches the middle of the rotor on one end and has a spring on the other that electrically connects to the coil.
I am trying to find a replacement but do not know what this part is called.
Thanks in advance.
Old Dec 17, 2011 | 08:06 PM
pancake's Avatar
pancake
It's called the contact button or center button.
Here's one
Old Dec 17, 2011 | 10:44 PM
GS977's Avatar
GS977
i have to make an order from summit soon, i will add one of those to my list the one in my hei is old.
Old Dec 17, 2011 | 10:52 PM
pancake's Avatar
pancake
Well hell, look at that.. You're just up the road in Springtown. Small world, isn't it!?
Old Dec 18, 2011 | 05:37 AM
LannyL81's Avatar
LannyL81
I have found these names since posting my question: distributor bushing, distributor contract, distributor resistor.
Appears that it depends upon the vendor....
I just need to get one as I thought I would try a 4 pin HEI distributor with associated carb on my '81...just to see if there is a difference.
The HEI distributor that was given to me needs a few parts and this was one of them. Does this contact normally come with a new cap and rotor, along with the rubber washer?
Old Dec 18, 2011 | 05:33 PM
GS977's Avatar
GS977
weatherford i'm in weatherford pretty often. i've seen quite a few c3s there. there seems to be alot of members on here from the dfw area.
Old Dec 18, 2011 | 05:37 PM
pancake's Avatar
pancake
A new cap should have the button in it.
To HEI Distributor Part Question
