79 vette 383 seems slow
Old Dec 18, 2011 | 06:24 PM
usnfenix's Avatar
usnfenix
Default 79 vette 383 seems slow
*delete*
Old Dec 18, 2011 | 06:44 PM
worship79's Avatar
worship79
I'd say your trans needs a higher stall convertor, but your end gear ratio is important too. Still 3.55 or other?
Besides that your TV cable might be off or some other OD issues perhaps.
Old Dec 18, 2011 | 07:16 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
In terms of importance with your current combination:
1. Ignition timing curve
2. Air-to-fuel ratio (carb tuning)
3. Exhaust and or intake restriction
Depending on the above and your compression ratio, a 383 should benefit with a cam about 5 to 10 degrees longer in duration.
Old Dec 18, 2011 | 07:37 PM
sly vette's Avatar
sly vette
I agree with the above post. Start by checking the timing.
Old Dec 19, 2011 | 11:17 AM
tracdogg2's Avatar
tracdogg2
What distributor are you using? It sounds like the mechanical advance isn't working.
Mike
Old Dec 19, 2011 | 01:16 PM
Rick_V's Avatar
Rick_V
How big are the tubes on your headers? I had a 86 Z-28 that I raced with a 383 in it. I had 1 5/8" headers. I talked a head pro about beefing up my heads he said he could rework the heads but the biggest problem was the small tubes on the headers. He recommended a minimum of 1 7/8" but 2" would be the best. Said the 383 engine couldn't breathe with the small tube headers. I put 1 7/8" headers on and gained .5 sec in the quarter mile.
Old Dec 19, 2011 | 04:36 PM
usnfenix's Avatar
usnfenix
below is a link to a thread where i posted the build sheets i got for the engine when i bought the car. it has compression data and timing data. this sheet and the data already posted is all i know about the engine
http://forums.corvetteforum.com/c3-t...m-my-79-a.html
Old Dec 19, 2011 | 04:37 PM
usnfenix's Avatar
usnfenix
Mike
mallory
Old Dec 19, 2011 | 04:41 PM
usnfenix's Avatar
usnfenix
shorty headers (ugh) they look pretty small, the max id say they are 1 3/4 primarys and they go down to 2.5 collectors, straight pipes are 2.5 as well. was better than previous setup, shorty headers with 2.5 inch pipe to ORIGINAL mullfers from 1979. car was quiet as hell you heard the fan reving over the engine. for now we cut the mufflers off somewhere about where the trans is and it sounds good but could sound a little better. my friends 331 with 1 7/8 primarys and 3'' collectors sounds deeper and louder
Old Dec 19, 2011 | 04:54 PM
worship79's Avatar
worship79
Let me get this straight:
- When you're at a stand still and then floor it, the car flies.
- When you're cruising and floor it, it also flies.
- When you're cruising and give throttle normally/gradually to increase speed it bogs down and/or picks up slowly.
Correct?
The bogging down, more so in the lower speeds? Or also when cruising at 60 mph?
Old Dec 19, 2011 | 04:59 PM
usnfenix's Avatar
usnfenix
Correct?
standing still and floor it, it roars and throws you back but a second later your sitting there like WTF? why didnt that acceleration go anywhere or continue? same thing from a roll. lots of noise but no go im telling you in a dig race id be fearful of pretty much anything. my camaro with only 340rwhp would rape this car.
so to answer, from any postion, flooring it gives you literally a 2 second burst of hell yeah then boggs down considerably
Old Dec 19, 2011 | 05:02 PM
usnfenix's Avatar
usnfenix
i dont know about the gears but i will say the rear looks like it hasnt been touched since 79, safe to assume stock gear ratio.
Old Dec 19, 2011 | 10:26 PM
larrywalk's Avatar
larrywalk
Sounds like the exhaust is very restrictive.
Old Dec 19, 2011 | 10:58 PM
couperdecar's Avatar
couperdecar
I'm no expert but I'm suspicious of that origional torque converter. If its weak it might be slipping. I'd look at replacing it anyway with a quality aftermarket higher stall. 2500 stall fine for the street.
Old Dec 19, 2011 | 11:42 PM
phil81's Avatar
phil81
hi there, I have the same feeling lack of power with my 81, 383, 700r4, 3.54 gears stock size converter 2200 stall,
Sure first gear is great lights up the tires but floor in in drive or leaving in 2nd or 3rd isnt that great . So after all my disspointment i ran it at the track 13.2 @ 103 i've since changed to an air gap manifold and tuning and run 12.5 @ 111 these seem to be pretty decent though my car still feels somewhat docile, I say run it at the track if you can to satisfy yourself, you maybe suprised. Yet I've been in cars that run high 13's that felt quiet scary and alot more powerful on the street. I've just had a custom 9.5" converter built and just about to install it , I hope to post results in near future
Old Dec 19, 2011 | 11:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Checked your fuel pressure under load?
What pump are you using?
Not a big cam for a 383 meaning its not going to scream up top like your LSx should still run strong though.
Old Dec 20, 2011 | 11:39 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Nothing new here.
#1 Timing curve, Set up according to Barry K's Tech article
#2 Vacuum advance can, Again get the correct can for your setup, Read Barry K's tech article on this.
#3 Make sure your throttle plates are opening fully. This sounds like a no brainer but you would be suprised how many cars I have seen that swapped out the carb and didn't get this right.
#4 A/F ratio. Difficult to get right without an A/F meter but again there is a tech article on this.
Many good builds are done that the owner installs the engine and slaps the distributor and carb back on without making the neccesary adjustments to accomodate the internal engine changes then wonder why they don't get the performance increase they expected.
To 79 vette 383 seems slow
