73 Smoking
Old Dec 20, 2011 | 12:13 PM
MidTex73's Avatar
MidTex73
Default 73 Smoking
My 1973 has been parked for about a year now, went to start it up and noticed a large amount of blueish smoke coming out the exhaust. Could this be due to oil or fuel? Or is it due to the length of time it's been parked. Any help would be appreciated! Seems to idle fine.
Old Dec 20, 2011 | 12:20 PM
brrujo's Avatar
brrujo
MidTex,
I also have a 73 with very low miles (46000) that does the same thing. I attribute my problem to 38 year old valve seals. Not a big deal, just annoying. I presume your smoking stops after a minute or so.
Where in Mid Tex are you located?
Old Dec 20, 2011 | 12:27 PM
CQRT's Avatar
CQRT
Originally Posted by brrujo
MidTex,
Run it more frequently, change the oil & filter and drive it a bit and that may lessen - - otherwise, it should disappear pretty quickly after start up or you'll need to look at valve seals and some head work.
Priya's Avatar
Priya
C3's sure look good in silver.
Old Dec 20, 2011 | 03:58 PM
MidTex73's Avatar
MidTex73
MidTex,
It continues after start up and warmed up for 30 minutes or so I would feel better if it stopped after a few minutes (valve guides). I live in Midland,Texas.
Old Dec 20, 2011 | 03:59 PM
MidTex73's Avatar
MidTex73
Thanks!
Old Dec 20, 2011 | 04:02 PM
MidTex73's Avatar
MidTex73
Thanks everyone! Probably going to the shop with it soon, tried to blame it on the carburetor, blueish/black smoke due to also smelling fuel in the exhaust. Still has the original Quadrajet with 80k on the odometer. Older restoration.
Old Dec 20, 2011 | 06:51 PM
Blue73Shark's Avatar
Blue73Shark
Does it happen only at idle or also when running? My 73 with th original Qjet had the same symptoms at idle. It was running too rich so I adjusted the 2 idle screws per advice from forum members:solved the problem.
Old Dec 20, 2011 | 06:55 PM
MidTex73's Avatar
MidTex73
It's happens during idle and when running. What are the recommendations for carb adjustment on the Qjets? I've heard run them in and back off 2 rounds and have also heard back them off 3 rounds. Any recommendations? Thanks!
Old Dec 20, 2011 | 07:02 PM
Blue73Shark
For my idle problem, I turned them in all the way, then backed them out 1 1/2 turns. It took about 4-5 turns to back them all the way down so it was pretty far out of wack. Plus I replaced the points condenser, rotor, distributor cap and plugs and tuned/timed it according to Lars' papers.
Old Dec 20, 2011 | 07:09 PM
LS4 PILOT's Avatar
LS4 PILOT
my 74 Camaro 350 , is very low miles and had all these symtoms , plus it rev'd a bit slow, sluggish . The guides ,springs ,ect all worn from age more than use not use. So had a machine shop , rebuilt head completely with all new parts, and had carb Q-Jet completely RESTORED , not rebuilt . All new vaccum hoses , bead blasted and painted the intake . New wires , plugs , ect . New rear main seal. The dang thing runs like dream , cranks easy, zero smoke and no oil use or leaks. Zips right up to 5500 RPM , doesn't miss a beat.
My Corvette is needing a top end job as well, nothing has been apart ever, the carb has a kit 25 years ago put in when I bought it , it has all the simular symtoms too now. I'm gathering parts ....maybe a cam too for this motor ...well see
Old Dec 20, 2011 | 07:27 PM
MidTex73's Avatar
MidTex73
Thanks! I'll try the 1 1/2 turn route. If I didn't want to keep it all numbers matching original, would opt for a different carb maybe a Holley 650. I have Lars papers on a thumbdrive somewhere, will go back and reference. New points, plugs, condensor,rotor and cap replaced a year ago only 150 miles on them. Will run a compression check tomorrow hopefully to get a better feel for what's going on.
Old Dec 20, 2011 | 07:29 PM
MidTex73's Avatar
MidTex73
Thanks! Love those 1st and 2nd gen Camaros! Going to run a compression check tomorrow, probably needing a top end as well.
To 73 Smoking
