Need advice on brake job
I want to preface this by asking that we not argue why or why not to change to silicone brake fluid. I've read a lot on that already.
Anyhow, included with the brake kit from Muskegon is 2 quarts of Dot 5 fluid. After reading several threads on here over the years, I know that you have to completely flush the Dot 3 out of the system if you change to dot 5. Most have said to use denatured alcohol.
I have a motive power bleeder, which will help.
Now for the questions:
1) Are there any write-ups that specifically detail how to do the denatured alcohol flush and change-over to Dot 5? I have some ideas, but am a little apprehensive about getting all of the dot 3 and all of the alcohol out of the system so that the only thing in the lines is the silicone based fluid. My thought is to alcohol flush with the old calipers & master cylinder on, change the hoses, MC & calipers out, and bleed the new set-up until I see blue fluid with no bubbles. Good idea or bad?
2) I haven't ruled out staying with Dot 3. Is there any readily available tinted dot 3? Is there a safe way to add a color tint to dot 3 so I can tell when I'm getting fresh fluid out of the bleeder screws?
3) Am I over-thinking this?
I'm guessing I will drive the car maybe 1500 miles per year after I get the brake system fixed. I've quit driving the car because of how little confidence I have in leaky calipers.
Thanks for the advice!
I'll keep an eye on this thread. Thanks everyone.
Duane
I drove it around the block last night & the brakes went from sort-of working to not working... to the point of putting the car in neutral and pushing it into the garage by hand.
I'm really excited about the project. The brakes have been crap ever since I've had the car.
