Correct speed for turn signals?
Old May 9, 2002 | 04:53 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Correct speed for turn signals?
Does anyone know how fast turn signals should flash on-off? I thought mine were flashing too fast so it was suggested that I replace the flasher unit to an electronic unit. I did, but I still think they're flashing too fast.
They're flashing about once a second!
Any suggestions?
Thanks.
Len
Old May 9, 2002 | 04:54 PM
Alwyn678's Avatar
Alwyn678
Default Re: Correct speed for turn signals? (1970 Stingray)
Mine do the exact same thing
Old May 9, 2002 | 05:31 PM
FeedVaal's Avatar
FeedVaal
Sounds about right to me.
Old May 12, 2002 | 06:56 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
After I thought about it, one blink per second isn't so bad so I went out and took another look.
The turn signals are blinking much faster than once per second----it's more like 3 times per second! :eek: Any ideas why?? :confused: It looks stupid too! :yesnod:
Old May 12, 2002 | 07:18 AM
Sharky Guam's Avatar
Sharky Guam
Signal flashers are built to flash about a second or so depending on the current load. The more current load there is, the faster they flash. You could try buying a heavy duty truck flasher designed for trucks that pull trailers. You might check to see if there is a problem with one of your light sockets. Corrosion or a frayed wire could cause an excessive load situation on the flasher.
Old May 12, 2002 | 08:01 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Correct speed for turn signals? (Sharky Guam)
Incorrect flasher??? Some are made for just turnsignals, some for turnsignals and 4 way flashers, some for "2 bulb" taillights, and some for "4 bulb" taillights. I'd check your owners manual, and see what was "correct" for your car, and then buy a comparable replacement, or an original. Hope this helps. Chuck
Old May 12, 2002 | 10:21 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Correct speed for turn signals? (Chuck Gongloff)
Len, at first I thought it sounded like you have a heavy duty flasher. Maybe the bulbs are the wrong size for your car. Still kinda sounds like what Chuck was saying.
To Correct speed for turn signals?
