rocker ratio.........
Old Dec 22, 2011 | 02:01 PM
ramair_bryan's Avatar
ramair_bryan
Default rocker ratio.........
My 81 in california has that 260 hp goodwrench replacement, so the previous owner says. I new if it had the original 190 it was making every bit of it. So It runs very well. But its all done at 4500 rpm. Very good torque . everything else is as it came from the factory. Looked at 1.6-1.7 rockers. It seems they open and close way quicker, as well as adding some duration.
so what do you think? It's cheep and easy. And Im dying to get oil all over everything. ramair.
Old Dec 22, 2011 | 02:08 PM
MelWff's Avatar
MelWff
They will increase lift only, the cam controls the duration and the ramp design on the cam controls the rate of opening and closing. If lucky you will gain 10HP but probably less. The engine has only 8.4 compression and very mild cam. Have you tried recurving your distributor?
Old Dec 22, 2011 | 02:25 PM
billla's Avatar
billla
St. Jude Donor '14
Installing 1.6 rockers will likely cause interference with the pushrod holes on those stock heads. There's a bit of power to be gained (10 HP or so) but it's not a great investment.
Regarding duration, changing rocker ratio doesn't change the actual duration...but it does increase the effective duration as the valves will also reach maximum lift faster, meaning that the valve will be open further, longer any time after initial lift so the "area under the curve" is greater.
Old Dec 22, 2011 | 05:59 PM
Snoopysvet's Avatar
Snoopysvet
Ecklers states a cam change is only good for 10 HP, I assume if the valve springs are still good.
Corvette Camshaft, 260 High Energy, Competition Cams, Small Block, 1955-1980
http://www.ecklerscorvette.com/corve...1955-1980.html
Old Dec 22, 2011 | 07:02 PM
BKbroiler's Avatar
BKbroiler
If your engine has Vortec heads, indicated by center bolt valve covers, 1.6 rockers will definately cause pushrod interference with the head, as billla suggested.
To rocker ratio.........
