Installed a Mallory UNILITE Conversion Kit but won't start
Old Jan 10, 2012 | 11:44 AM
  #41
Auto5's Avatar
Auto5
I run a Mallory magnetic breakerless distibutor pn 5764501H w/mech. tach drive & vac advance, no filters for the last 4 years with no issues on my '63. I do not use a ballast resistor but run a Accel 8140C coil that due to the length/type of windings within the coil, provide 1,4 ohms of resistance. The coil looks like a regular coil other than it's chrome. It might be available in plain black. Worked for me.
Old Jan 10, 2012 | 12:38 PM
  #42
ezobens's Avatar
ezobens
Great find!
Accel's doc clearly states this coil does not need a ballast.
Thanks for the tip!
Elm
Old Jan 10, 2012 | 10:19 PM
  #43
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by ezobens
I really do appreciate your engineering knowledge and since most of us (including myself) don't have access to an oscilloscope I cannot answer your questions. Perhaps you would like to share with all of us the answer now so you don't have to bring it up for a 68th time?
(insert smile here)- If you know something, this is the place to share, not to argue. I'm not arguing. I'm trying to correct things when technical inaccuracies are posted. After spending a couple decades designing ignition modules, ECMs and PCM, I'll confess I do find it frustrating when I'm told I'm full of crap.
I don't claim to know everything but I do like to learn. I share what I've found in my travels working with this stuff over the years and if I'm not 'technically' accurate I apologize but that doesn't necessarily make my assessment invalid.
My question to you is if a coil is "labeled" as 12 volts yet requires the use of a ballast resistor in order to keep it from self-destructing at a full 12 volts, is it truly a 12 volt coil? I don't know. (How's that for an honest answer? ) As an engineer who uses inductors (coils) in projects such as engine and transmission controls, a "12 Volt" label means nothing. The only pertinent descriptions (regarding inductors) are its inductance, winding resistance, turns ratio if it's a transformer type inductor, maximum current before the wires burn open, insulative/dielectric strength, and a couple other more boring specs. Stamping 12V on the coil housing tells me nothing. As an ignition coil is an energy storage device (designed to quickly dump that energy into the plug gap) there's two main items that describe the magnitude of that energy. Those are the inductance (more or less how much windings there are in the primary) and the current level just prior to the points opening (Energy = 1/2 LI^2). Note a couple things. When the inductance is increased (more windings) that the energy potential goes up. When the current goes up, the energy goes up by the square of that current (doubling the current give you four times the energy). Note also that voltage is nowhere to be found in the energy formula. In my mind, a true 12 volt coil would wouldn't require external circuitry to keep it alive. I understand what you're saying. That perception makes sense. While I don't understand where the 12V label originated from (as it makes no engineering sense), I suppose this odd label could also be be applied to 12V starters, which will blow up if continually hooked up to 12 volts. Please explain where my theory falls off the tracks.
Thank You
Elm
I offered up my two questions in an earlier post in an effort to invite some thought into how an ignition coil actually works. To my great disappointment I rarely get a response to them. I get annoyed at the snake oil claims in a lot of ignition system marketing, and shake my head at all the money that gets spent on essentially bling, as there's no technical information considered before the credit card is pulled out. I realize it's not my money, but I appreciate when someone can enlighten me on aspects of the automotive world that I may be less than proficient at, and helping prevent me from throwing good money at bad merchandise, and I try to return the "favor" when it comes to a subject I'm somewhat versed at. But, engineering facts are often boring, and some (I'm excluding you) find it easier to just buy the shiny stuff rather than spend the time to try to understand how it actually works.
I've probably written more here than most will read, but if you have any specific items or questions you'd like to discuss, I'm happy to pass on whatever information I can. I didn't invent any of the pertinent laws of physics, but I had the good fortune to work with and learn from many talented individuals in the automotive electronics industry (including having the designer of the HEI module as my mentor when I went to work after graduating from college). I don't have any need to keep this information just to myself.
Old Jan 11, 2012 | 01:15 AM
  #44
hdpete98's Avatar
hdpete98
Pete,
Can you share the specific coil you are using?
I have not been able to find a "Mallory" canister coil that is compatible with Mallory's Unilite or Magnetic pick-up coils and didn't need a ballast. Is it another brand?
Thanks!
Elm
Mallory Coil #29219. $45 at Amazon.
Old Jan 11, 2012 | 09:00 AM
  #45
ezobens's Avatar
ezobens
Pete,
I don't want to alarm you but I have 2 dead 29219 coils on my shelf that boiled the oil out of them after about 8 hours run time each in my boat.
I too have the Mallory doc that clearly states that this coil doesn't require a ballast with the electronic trigger and after repeated calls to their tech support for an answer, I finally got a hold of someone that confessed that this coil actually DOES need a ballast but the doc in the box is wrong. Sounds like it hasn't been revised.
You probably haven't run it long or hard enough to be an issue but I'd keep an eye on it. How hot does it get after you run the car?
Mine got so hot, I couldn't touch them.
Elm
Old Jan 11, 2012 | 09:11 AM
  #46
ezobens's Avatar
ezobens
You're the guy I need to know!
I too try to share what knowledge I know (even if I may be off on the engineering at times) but I don't try to steer anyone in the wrong direction. I've wasted my share of dollars on parts that aren't compatible or just simply don't work so I've perhaps grown a bit cynical in my old age. I apologize if I came across as not believing your information, that was not my intent. Finding folks on-line that have actual experience with something vs hearsay and armchair opinions is surprisingly hard to come by. That's probably why I preface most questions I post with the caveat "has anyone had actual experience" lol.
I'd still like to know the answer to your 2 questions but we can do that off-line.
Sorry to high-jack the OPs thread!
Back to the question at hand.
Is it safe to say we agree that the trigger for the ignition should always run at full 12 volts (unless you are running points) and the coil may or may not need a ballast based on manufacturer specifications (hoping their doc is accurate)?
Any luck in troubleshooting your Unilite issue?
Elm
Old Jan 11, 2012 | 11:51 AM
  #47
69427's Avatar
69427
I'd still like to know the answer to your 2 questions but we can do that off-line. Can do. Sorry to high-jack the OPs thread!
Is it safe to say we agree that the trigger for the ignition should always run at full 12 volts (unless you are running points) and the coil may or may not need a ballast based on manufacturer specifications (hoping their doc is accurate)? Yes. While it is possible to run an ignition module off of the C+ line (with a ballast), it just adds additional problems due to the ripple of the supply line every time the dwell turns on and off, plus you lose "headroom" as the module might not work at all if the battery drops a few volts during a flooded carb long crank time. Regarding the coil, unless the manufacturer explicitly says "this or that", I would default to an assumption that it's a fragile piece of equipment and needs a ballast in point applications (and simple electronic conversions), while the more sophisticated electronic systems with active dwell control (HEI, PertronixIII IIRC) monitor and control the actual current to keep things safe, and thereby don't need a ballast resistor.
Elm
Yeah, I'm curious if he's making progress.
Old Jan 17, 2012 | 04:28 PM
  #48
hdpete98's Avatar
hdpete98
Pete,
Elm
The first one installed did that. Mallory replaced it and I have been running it in my daily driver for six months with no issues.
Old Jan 17, 2012 | 04:42 PM
  #49
cokerintennessee's Avatar
cokerintennessee
After more research I found most people running the #558 Unilite Conversion were also running the #30450 Mallory Coil. I've now installed the Unilite Converstion with the #30450 Electronic Coil and thus far, fingers crossed and lots of prayers.......it's running great. Starts like it should, goes through the gears at high RPM with no issues. Time will tell.
Thanks for taking the time to add to the conversation. I really appreciate that.
Ron
Old Jan 17, 2012 | 04:47 PM
  #50
cokerintennessee
All is running great.....right now......Mallory #558 Unilite Converstion with Mallory #30450 Pro E series Coil. Big difference! Time will tell and if I experience problems, I'll be back!
Thanks to all who have joined in this conversation. It was wonderful to hear from those who know something and actually care enough to help solve a problem.
Ron
Old Jan 17, 2012 | 04:49 PM
  #51
cokerintennessee
Ron
And also, no ballast resistor needed.
Old Jan 17, 2012 | 05:49 PM
  #52
ezobens's Avatar
ezobens
Glad to hear you're back in business!!
Hope it's smooth sailing from here on out ;-)
Elm
