Installed a Mallory UNILITE Conversion Kit but won't start
I've just installed a new Mallory Unilite Conversion in my Mallory Distributor. When I crank it, it seems to fire up and rev but then dies, almost like I shut the key off. I did not change the timing. I did have to make a value judgement concerning using a Ballast Resistor as I did not have one installed using the old dual points and condenser set up. Any ideas on what I should try next? Thanks in advance and Merry Christmas to all!
You need the ballast resistor and wire it like the directions. You are exhibiting the common failure of the ballast R where the car runs when the starter is engaged and shuts of when the ignition is just "ON"
Just ordered one on line. Hope that fixes it! Thank you for taking your time to respond. Merry Christmas!
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Ron
I'm assuming you had a substitute wire (in lieu of the ballast) on your points setup. If that was still hooked up I would assume the new setup should start too. Was that wire removed? Also, does the Unilite require a ballast, or does the module control the current level?
I ran the M Unilite for 10 years and it said to use a BR You can look at the wiring setup online.
The unilite requires a balast resistor if you are not using the OEM resistance wire.
Unless that wire has been removed/bypassed, there is no need for an additional ballast resistor.
The instructions which came with the Unline states: "The purpose of an ignition ballast resistor between the ignition switch (12V) and the ignition coil positive terminal is to restrict current flow through the ignition coil. Failure to use an ignition ballast resistor will eventually destroy the Ignition Module." And yes, I had a substitute wire running from the ignition switch to the positive pole on the coil when I was running the dual point/condenser set up.
My installation is consistent with Figure #1....with the exception that I used an older ballast resister. I'm hoping that is the problem. I've got one on the way and should be hear after Christmas. Still open for more ideas to try. Thanks! and Merry Christmas!
You can put a wire to jumper the resistor out. Or just Ohm meter it to see if the BR reads 1.0 - 1.4 ohms
do you have 2 wires going to your coil? One comes from the starter and provides additional current when cranking. once you release the ignition key swith and it returns to the on position, the current is cut and is supplied through the second wire that is part of wiring coming from ignition switch. If the second wire is not connected, your engine will die as if you turned of key because, effectively, that is what you have done if second wire not attached.
Mallory is telling me I have the wrong coil (points type) model #29217. Mallory is suggesting model #30450 or #29450. HATE to lose the look of the old canister style coil.....
What's the electrical differences between these coils?
There is absolutely no useful information in either of those links. My suggestion is to either call Mallory and ask for some actual information/specs on these coils and your module, or throw the whole mess in the trash can and buy a brand who's not afraid to tell you what you're actually getting.
Also, if the tech rep has to ask you what info you need, you are correct to assume he doesn't know WTH he's doing.
Reason: Spelling correction.
I've now installed the new coil with the Unilite conversion. I've taken the resister out of the positive electrical line from the ignition/starter/ + line to the coil. The motor fires up, runs for 2 seconds and then cuts off. New ideas?
