Functional Fog Lights or Running Lights
I have an '81. I was trying to figure if there is any room to add or install some sort of Fog lights or Running lights. I'm just try to put more "light" on the road in the immediate front area. The standard Headlights are fine for distance, however I just didn't know if anyone has expanded the lumination prospects. Thanks and Merry Christmas to everyone. I have learned a lot on this forum.
Mine are controlled by an LED toggle switch under the dash. They are ignition-switched at the IGN terminal on the fuse box.
My 1979 was set up with Hella 1500s behind the grilles. But with your year that will not work as your grille slats are slanted and the lights will not shine through.
You can install daytime running lights (DRLs) with an electronic module kit (and #2357 bulbs). These give you much more frontal illumination to oncoming traffic. The re-wiring will take about three hours and only involve splicing into the front parking lamp harness extensions, not the wiring harness per se.
Thanks, Paul. So if I'm following you correctly, you have the switch to turn the lights on. Are your turn signals able to work too with the lights on? I would think yes since there are two bulbs? Cars look great. That is what I was thinking of. I didn't know there was a lot of difference in the 79 & 81 grill. I will be checking mine out in the morning for sure. Thanks for the reply Paul.
Mark
Is there actually a noticeable difference in the light the car throws through the turn signals? What size bulbs are you running?
Mark
Mark
I can't link to a non-sponsoring vendor here but Google WebElectric and check DRL-1. The signals work normally in sync mode. In fact perfectly. The toggle switch is my mod. In the absence of it things are just a normal ignition-switched function: always on. I just wanted an on/off option with the toggle. It does require wiring back from the front to the fuse box but not a major issue.
Here is the DRL control module. (Excuse my Goop.) It looks a little complicated but really it is not. There are not two bulbs. The system operates on the completely stock parking lamps: on the bright (turn signal filaments) of the normal #1157 bulbs. I chose to go a little brighter with #2357 bulbs
Here is the wiring diagram. I used mostly soldered connections, with shrink wrap, but wimped out a bit on several scotch-lock ones. Just to reiterate you are working on your front lamp harness extensions not the harness itself. No major injuries incurred if you foul up. I really like this mod. It adds a major driving safety factor to my car. Since I originally posted on this I have had some negative comments but it does much more good than harm. And you are using factory electrical demands: no relays or whatever.
Up to 1979 the grille slats were completely horizontal. With the the 1980- they were slanted. Hence my comment.
If you wish to go with fog lamps you have to find a place to hang them. This mod preserves the original look.
Hey guys this is my first post on the CF, I have a 1970 convertible, and I am looking to mount two driving lights in place of my license plate. Any recommendations on a power source to tap into. Or do I have to go all the way back to the battery? I would really like the switch to be operated on the ignition.
