81 Vette Ignition Problems
Old Dec 24, 2011 | 05:22 PM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
Default 81 Vette Ignition Problems
Was doing a little idle adjustments and checking vac pressure so I was stating and stopping the engine. Then I went to start it again and nothing. Everything else works great, the wipers, lights, radio, turn signals just nothing to the starter. The battery has a full charge and I'm getting power to the power side of the starter. I'm trying to do this alone so I can't tell if I'm getting power to the starter when I turn the key but I don't believe I am because I can short across the starter and the starter turns. Any help would be greatly appreciated.
Old Dec 24, 2011 | 07:00 PM
maxmachz's Avatar
maxmachz
Perhaps the neutral safety switch? Try moving the shifter if it's an auto, the clutch pedal if its a 4 speed.
Hope this helps.
Old Dec 24, 2011 | 07:21 PM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
Thanks but I tried that with no luck.
Old Dec 24, 2011 | 07:37 PM
maxmachz's Avatar
maxmachz
Shop manual shows a starter interrupt relay, but does not tell where it is...manual is nice but VERY cryptic. Also tried to paste the verbage off of it to get you the procedure to test it, but, won't let me copy or paste......will keep trying.
Old Dec 24, 2011 | 07:40 PM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
Thanks, anything will be a great help because I'm in the dark on this one.
Old Dec 24, 2011 | 07:51 PM
terry82's Avatar
terry82
if you have no one to turn the key for you ,make up a long jumper wire with a clip on both ends for the ignition wire .put the other end on on test light see if it lights when you hit the key.what i would check is the wire connector behind the passenger motor head.your starter wires pass thru there .its a common place for the connections to go bad.look for a connector[with out checking i think] with 6 wires.
Old Dec 24, 2011 | 07:57 PM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
Thanks I'll do it first thing in the morning
Old Dec 24, 2011 | 09:43 PM
LannyL81's Avatar
LannyL81
Fuseable link.
Old Dec 25, 2011 | 09:38 AM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
Where would I find the fuseable link
To 81 Vette Ignition Problems
