Wiper Pump Connectors
Old Dec 25, 2011 | 10:47 AM
JSVette's Avatar
JSVette
Default Wiper Pump Connectors
Merry Xmas to everyone. Bought a new engine harness for a 1970 coupe and I need a photo showing the connectors to the wiper pump. The current connectors I have must be incorrect.
Jeff
Old Dec 25, 2011 | 11:02 AM
qtlow's Avatar
qtlow
Default Adapter.
I believe the 70 uses an adapter with 2 bullet type connectors that plugs into the harness then a big connector that plugs into the washer pump. Corvette Central part # 663330.
Hope this helps.
Picture.
Old Dec 25, 2011 | 12:01 PM
C6DuffMan's Avatar
C6DuffMan
That adapter is only needed for aftermarket replacement type wiper pumps. The factory pump used the barrel type connectors and the yellow and blues wires were separate from each other. You can still get wiper pumps that have the correct factory type connectors. I just bought one.
Old Dec 25, 2011 | 08:41 PM
JSVette's Avatar
JSVette
Thanks gtlow! That's exactly what I am looking for. I will need to order up a new one as my has been modiflied by Bubba.
To Wiper Pump Connectors
