Half shaft or u-joint the determining factor?
Old Dec 26, 2011 | 06:43 PM
gbarmore's Avatar
gbarmore
Default Half shaft or u-joint the determining factor?
I was just finishing up painting the half shafts on my 80 when the bailing wire holding it broke and it came crashing down on my cement floor. Can you guess how it landed and what happened?? That's right, I now have a 1/8" dent in the U-Joint seat and it's toast so I need to find a new one. I know the u-joints are different between Automatic and manual cars, but the question is are all 3" half shafts the same size, and just use different u-joints, or are the half shafts themselves actually different between manual and auto? Bottom line is I need a new one and really want to find one used vs spending $190 on new. Thanks for any help!
Old Dec 26, 2011 | 09:42 PM
tracdogg2's Avatar
tracdogg2
Is your vette an auto or standard trans?
Mike
Old Dec 26, 2011 | 11:53 PM
gbarmore's Avatar
gbarmore
Sorry, should have stated that.... I have an Auto...
Old Dec 27, 2011 | 08:16 AM
KENS80V's Avatar
KENS80V
You can take the damaged halfshaft to a place that does driveshafts and have a new yoke installed. The original yoke can be removed and a new one installed/welded then balanced.
Old Dec 27, 2011 | 08:23 AM
gbarmore's Avatar
gbarmore
I had not thought about that, figured it was trash. I will call around and see if I can find someone that will do that. Thanks for the advice!
Old Dec 27, 2011 | 10:37 AM
willem wallace's Avatar
willem wallace
Default half shaft
I would call Fort Wayne Clutch, and compare price of new unit to a repair. They do nice work, reasonable!
To Half shaft or u-joint the determining factor?
