Bellhousing removal
Old Dec 26, 2011 | 09:57 PM
jcloving's Avatar
jcloving
Default Bellhousing removal
Guys,
I searched but could not find this.
I pulled the tranny today but could not get the bellhousing off. I pulled the six bolts, but it would not budge. I think the dowel pins are the only things holding it on. I pulled the starter and flywheel cover already.
Can I pry it off gently somehow?
Please help. I need some advice on how to pull that bellhousing.
John
Old Dec 26, 2011 | 10:20 PM
Big Block Dave's Avatar
Big Block Dave
Yes, its just the dowel pins. Just get a wide and flat pry bar or screw driver to gently nudge in between the block and the bell...kind of like working the lid off of a paint can. Its probably possible to chip one [although unlikely] so just use common sense as you work around. Realistically it will take one to two tries
Old Dec 27, 2011 | 07:49 AM
newbie2vette's Avatar
newbie2vette
I was faced with the same situation seveal weeks ago when I wanted to paint mine, take a rubber hammer and tap on the lower and upper part "rock it" as they say. It will come out, after you removed the four bolts that holds it.
Old Dec 27, 2011 | 08:41 AM
Garys 68's Avatar
Garys 68
knock/pry it off or drive the pins through
Old Dec 27, 2011 | 10:02 AM
jcloving's Avatar
jcloving
Thanks Guys, that was just what I needed.
To Bellhousing removal
