1970 LS-1 pics
Old May 9, 2002 | 10:58 PM
70 LS1's Avatar
70 LS1
Default 1970 LS-1 pics
As promised here are some pics of the LS-1 installed in my 1970. The pics are kinda dark so bear with me. The first one shows the LS-1 in the car with the fuel rail covers installed. You can't really tell, but I painted some cool color change flames on them. I used that mirage paint by duplicolor and it changes from gold to a magenta color. Looks really cool in the light. In the background you can see a huge bundle of wires leading to the computer which is mounted on the backside of the inner fender. It fit really well there.
I made the custom alternator bracket out of aluminum then clear coated it for a nice shine.
You can also see the C5 air intake that goes up and over the radiator. I really liked the way this turned out. A section of the radiator support was cut out and lowered a few inches to allow room for the hood to close. I added the bellows in the front to drop the MAF and huge conical K&N filter. I looked at it from every conceivable angle and I am confident that the hood will still be able to open all the way. (Don't mind the dirty bellows, I still have some detailing to do.) The mass of blue wires off the the left go from the fan relays to the fans. I used the fans from the donor Camaro and wanted to keep them controlled by the computer. They run in series for slow speed and in parallel for fast. I went and picked up some relays(3 of them) and wired them into the circuit. I also have a switch under the dash that lets me turn them on in slow. All of the wires will be encased in the Taylors convoluted tubing. That stuff just gives a neat and tidy look.
I didn't feel like spending the several hundred dollars for a premade wiring harness, so I spliced the 99 Camaro harness with the 70 Corvette harness. I studied the schematics, determined where I needed fuses and removed all of the wires I did not need (i.e. EGR, A/C, AIR, etc.) I picked up a fuse block from painless and wired it in.
One of the problems I had to overcome was the factory Vehicle Anti-Theft System (VATS). The newer GM cars have this system where they have a resistor in the key. If you use a key with the wrong resistance, the car will think it is being stolen and not allow the fuel injectors to turn on. I needed to convince the computer with the correct signal so it would allow the injectors to fire. I built a removeable 5V 50Hz signal generator that can fit in my pocket. Even if the car was hotwired, it would run out of gas in about 2 seconds.
Another problem was with the transmission. I am using a T-56 which has the shifter come right out the middle. The muncie had it just off center. I had a buddy of mine cot off the top of the T-56 shifter and the bottom off of the mucie shifter handle. He then welded them together with a spacer and everything fits nicely under the original console. My whole goal from the begining was to have the car look completely stock until you open the hood.
I love the way these cars look with the LT-1 hood stripes, so I decided to keep it with one modification. I had a buddy of mine who is in the vinyl cutting business make me a set of LS-1 decals for the hood.
Right now, the only gauges that work are fuel level and the ammeter. I think I have figured out a way to get them all to work with this setup. I still need to hook up the clutch and then she is roadworthy. At least good enough to drive it to the exhaust shop.
I will keep you updated.
[Modified by 70 LS1, 7:00 PM 5/9/2002]
Old May 9, 2002 | 11:08 PM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: 1970 LS-1 pics (70 LS1)
Sweet :cool: You can certainly tell how much lower the LS-1 sits in the car.
AC
Old May 9, 2002 | 11:15 PM
Fevre's Avatar
Fevre
Wow that is cool as hell.
I am waiting to hear on a Ram jet and praying I get it at this nice price. I am installing a 5 speed (not sure which one yet) but had the same idea for the shifter but I was think one step further. Instead of weld my original, buy the after market hurst and drill the shifter shaft from the trany. Also drill holes in a piece of aluminum and run 2 bolts through all three. Then you can take it apart if it gets in the way for any reason.
Old May 9, 2002 | 11:17 PM
razz1980's Avatar
razz1980
Default Re: 1970 LS-1 pics (A C)
man that sits low in the vette.u got alotta room to play with on the top end huh :jester
Old May 9, 2002 | 11:19 PM
78Vette-SA's Avatar
78Vette-SA
Jeff,
You are a trailblazer. :smash: You're setup is much neater and cleaner than the one Vette Mag is doing in their 75. Hats :hat off to you and keep up the great work, and keep sending pics!
:cheers: :chevy :cheers:
Old May 10, 2002 | 12:04 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
That is one sweet ride :yesnod: :yesnod:
When I grow up, I want one just like it :D (or maybe LS6 :reddevil )
Looks very cool, have you been able to start it up yet?
Old May 10, 2002 | 12:12 AM
Barry's70LT1's Avatar
Barry's70LT1
Very Very nice...!!!! :)
Old May 10, 2002 | 12:26 AM
70 LS1's Avatar
70 LS1
Default Re: 1970 LS-1 pics (Buffalo Dude)
Buffalo Dude - I was able to start it up yesterday and it ran beautifully. Can't wait to drive it.
Old May 10, 2002 | 03:37 AM
TracerX's Avatar
TracerX
Very nice Jeff! :cool:
I love having LS1 power in my 84
Old May 10, 2002 | 08:07 AM
MassVette's Avatar
MassVette
Nice install! :yesnod: :chevy :chevy :yesnod:
Old May 10, 2002 | 08:13 AM
groovyjay's Avatar
groovyjay
Default Re: 1970 LS-1 pics (MassVette)
Looks like someone's been really busy! Looks great! :yesnod:
Old May 10, 2002 | 08:30 AM
QuickVet's Avatar
QuickVet
Default Re: 1970 LS-1 pics (groovyjay)
:cool:
Old May 10, 2002 | 09:31 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: 1970 LS-1 pics (QuickVet)
Congrats to the guy that is going to be the first LS-1 driven C-3. :cheers: Please have someone video the maiden voyage. Can wait to that. I think you have done great job. Roll on. :cool:
Old May 10, 2002 | 09:49 AM
vettedan's Avatar
vettedan
Jeff- Lookin good! I put a switch in series with the VAT resistor (key) and hid it. Whenever I leave my shark, I engage it. Sorry I still haven't made it up to your place, but with a new addition (son) and work, it's been crazy. Don't lose Hope ! I might have to copy your set up with the snorkel. I hope you won't mind? :cool: :cool: :cool: :cheers:
Old May 10, 2002 | 09:51 AM
Alwyn678's Avatar
Alwyn678
Default Re: 1970 LS-1 pics (vettedan)
Looks GREAT :cheers:
Old May 10, 2002 | 09:56 AM
ylose's Avatar
ylose
Default Re: 1970 LS-1 pics (Alwyn678)
:cool: :cheers: :cool: :cheers: :cool:
Old May 10, 2002 | 11:51 AM
stickboy's Avatar
stickboy
looks great :cheers:
To 1970 LS-1 pics
Old May 10, 2002 | 12:02 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
That is very cool and something I may be doing in a little while. Good job.
Old May 10, 2002 | 06:34 PM
70 LS1's Avatar
70 LS1
Default Re: 1970 LS-1 pics (burners)
Thanks for all the compliments. I am going to try to get the clutch all hooked up this weekend and get her on the road.
Old May 10, 2002 | 09:14 PM
paso's Avatar
paso
Nice Job Jeff. Keep the photo's coming:)
