Internal or External 383 stroker kit?
Old Dec 28, 2011 | 04:13 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Originally Posted by BLOCKMAN
What SBC has GM been selling for 40 years with out of weight balancers???
Could you quote who said anything else is garbage as I can't find that post!!!!
I didnt say SBC, I said engines. The 400 & 454 were both introduced in 1970.
The 454 is of course still in production. If you want a current sbc example, just look to the zz383.
I realize you didnt use the word garbage, but you did say it was asking for trouble.
I didn't think exact wording was such a big deal.
Old Dec 28, 2011 | 04:20 PM
BLOCKMAN's Avatar
BLOCKMAN
Originally Posted by Manuel Azevedo
(1) I didn't really see anyone in particular say everything else is junk!
(2) 400CI GM's Assuming this poster meant external balanced dampeners.
I believe the 400 SBC was only built for 5 or 6 years not 40 years
Old Dec 28, 2011 | 04:23 PM
BLOCKMAN's Avatar
BLOCKMAN
The ZZ383 uses a neutral balancer on the front of their engines but is externally balanced on the rear.
This thread was about 383's not 454's but if in case you didn't know the 454 uses a much larger snout then the SBC.
Old Dec 28, 2011 | 04:28 PM
billla's Avatar
billla
St. Jude Donor '14
Don't understand why this subject gets so out of hand but it does.
It's just a matter of what's right for the application. I think it's the absolutes - either way - that get people riled up.
(2) is the additional dollars a shop gets for this work and for some people to have another BENCH racing thing to talk about!!
Old Dec 28, 2011 | 04:38 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Are you sure about that? The balancer part number for the engine is 1249800.
You can take a look at one here - http://www.race-mart.com/GM_Performa...-12498008.html
From what I'm reading, that's an externally balanced piece.
Old Dec 28, 2011 | 04:49 PM
BLOCKMAN's Avatar
BLOCKMAN
Don't understand why this subject gets so out of hand but it does. The Truth of this internal external argument is that there is really two reasons why internal balance is better!
(1) is the ease of replacing clutches and such and still be able to balance them to work in the engine and the cost savings in some cases in not buying external balance parts, though the added cost of internal balancing may off set this some.
I have seen alot of guys drag in an internally balanced rotator with their neutral balanced flywheel and balancer only to have to charge them for new externally balanced flywheel and balancer which is good for me but not the customer plus extra money to push the balancer on and put on the flywheel. Then you have to strip everything off and polish the crank as the cast cranks have never been polished but have a grind finish!!!!!
So I make out pretty good and the customer has to spend extra money LOL!!!
An externally balanced SBC on the front is more of a weak link compared to an internally balanced rotator plus external is more costly for the consumer
Old Dec 28, 2011 | 05:02 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
For me the decision to spend extra $ stronger parts or better build techniques boils down to how much I'll have to worry every time I put my foot in it. When I know the engine, trans, and driveline are up to the task of taking the torque my engine will produce and the engine is tight through the rpm range, then I can straighten my right leg and smile at the same time.
BLOCKMAN's Avatar
BLOCKMAN
Yes that engine is exteranlly balanced on the front another interesting note on those engines they use a 4340 crank which is a plus compared to a cast crank!!!
I doubt its been made for the last 40 years!!!!!
Old Dec 28, 2011 | 05:19 PM
worship79's Avatar
worship79
Okay, thanks guys. It's clear to me
Old Dec 28, 2011 | 05:50 PM
C3Paul's Avatar
C3Paul
How do the Internal front and External rear, hybrid one piece rear late SBC rotating kits compare?
Old Dec 28, 2011 | 11:32 PM
Indiancreek's Avatar
Indiancreek
The issue I see is that the weight on internal balanced engine is bearinged on both sides of the counter weight. On the external the counter weight has the additional weight beyond number 1 and 5 main bearing. These weights, number 1 more than 5 are forward unsupported.
Balanced well both will work. I think at higher Rs the internal will last longer maybe. They are engines and by there nature will fail. Just do the best you can aford, to make that point in time later more than sooner.
Longer rods do as Blockman says. I think there is a point when extreemly long can reduce a life span also.
