engine whoas
Old Dec 28, 2011 | 02:57 PM
gmg1977's Avatar
gmg1977
Default engine whoas
ok after a year I finally have some time to work on the mistress. When I try to start it, the crank moves slow and just sputters like an old bi-plane. I have a new fuel pump, coil, and starter, battery, along with a new cap and rotor. The engine is a fresh built 496 big boy with a 750 holley carb, that ran last when it was at the dyno. It is defanatly getting fuel. It turns over as soon as I turn the key but it just doesnt seem like it gets enough momentum to fully run. I did put new gas in and have replaced all the rubber hoses. Im thinking it is something simple, perhaps just need to add some starting fluid but I thought i would ask the experts before I did something to blow up the engine.
thanks
Old Dec 28, 2011 | 03:50 PM
fanmanbd's Avatar
fanmanbd
Did you remove or turn the distributor since it last ran. Sounds like your initial timing is off or just a weak battery.
Old Dec 28, 2011 | 04:01 PM
gmg1977's Avatar
gmg1977
I did but I put everything back. At the 0 timing mark it is at the #1 position. Could be the battery but I just put in a brand new one today. If it was anything with that I was thinking the battery cables. They are def the originals.
Old Dec 28, 2011 | 05:06 PM
billla's Avatar
billla
St. Jude Donor '14
It's not going to start or run at TDC timing
Start with around 12-14 BTDC and then tune from there
Old Dec 28, 2011 | 05:24 PM
gmg1977's Avatar
gmg1977
That could be it then. As you prob can tell im no pro. Just built it out of a book and stuff I read here.
Old Dec 28, 2011 | 05:53 PM
billsfan's Avatar
billsfan
Remember, the engine turns over twice for every distributor rotation. Be sure that your engine is on the compression stroke when you set the distributor to #1 cylinder. Also check that your wires are routed properly. If all is OK, try turning the distributor slightly while you are starting it.
Old Dec 28, 2011 | 06:16 PM
billla's Avatar
billla
St. Jude Donor '14
Good catches and things to check to ensure everything is right on - my snap answer didn't include these.
Old Dec 28, 2011 | 06:28 PM
gmg1977's Avatar
gmg1977
Sweet thanks. I thought I read somewhere that 0 mark on the balancer = set the distributor to #1. Good to kno there are peeps that know much more than me on here.
To engine whoas
