1976 assistance needed
Old Dec 28, 2011 | 08:49 PM
3 or 88's Avatar
3 or 88
Default 1976 assistance needed
My daughter is doing some engine work and have have a couple questions.....
need some torque specs for intake manifold and tightening sequence if anyone could assist would be much appreciated.
I am also thinking of eliminating smog pump... any suggestions as to what I should look out for or re-route or eliminate lines....
Thanks in advance for the info; I had manual on computer and cannot locate... thanks again for any assistance
Old Dec 28, 2011 | 08:57 PM
1986coupe's Avatar
1986coupe
30 ft pounds.
Your car but why remove smog pump? I have a 1976 and when I originally got it there wasn't any emissions equipment on it. I put all of the emissions equipment on so that the government here couldn't fine me. No noticeable change in performance. The smog pump simply puts air into the exhaust system to help burn off emissions.
Old Dec 28, 2011 | 09:16 PM
3 or 88's Avatar
3 or 88
I think the engine bay would look better without.... the 30lbs on intake; do you know the tightening sequence?
Old Dec 28, 2011 | 09:39 PM
1986coupe's Avatar
1986coupe
I have it in books. Did a search on google and found this.
http://www.longislandvettesclub.com/...draw/td208.jpg
To 1976 assistance needed
