How do I fix this leak?
Old Dec 31, 2011 | 03:03 PM
Snoopysvet's Avatar
Snoopysvet
Default How do I fix this leak?
Steering Issues
Old Dec 31, 2011 | 03:17 PM
RedZR's Avatar
RedZR
Default How do I fix this leak? Reply to Thread
Actually its not that difficult. You can by a kit (I think its around $12.00) that contains the ram seal. Simply remove the ram from the car and remove the snap ring on the end and pull the leather wiper and seal out and replace it with a new one.
I did it to my 78 a few months ago and it solved the leak.
Here are the posts that helped me:
http://forums.corvetteforum.com/c3-t...nder-seal.html
Dan
Old Dec 31, 2011 | 03:24 PM
thegazman's Avatar
thegazman
Default thegazman
Dan
Dan is right on this. I haven't seen the repair cylinder repair as cheap as $12, but Corvette Central sales them for $17.95. How's the weather in San Diego? My son lives in an area called Kensington & always calls to tell how the weather is in San Diego when it's snowing here.
Old Dec 31, 2011 | 03:28 PM
redwingvette's Avatar
redwingvette
You can try a new seal kit and rebuild the cylinder or buy a replacement one. The valve is probably leaking as well so you could buy the complete kit.
Power steering parts
Or you could use this as a reason to upgrade to Rack & Pinion or a Borgenson box and eliminate the mess altogether.
Old Dec 31, 2011 | 04:29 PM
Snoopysvet's Avatar
Snoopysvet
Beautiful today in San Diego, thanx for all the help!
Old Dec 31, 2011 | 08:53 PM
Drawmain's Avatar
Drawmain
Check out this link, walks you through the entire process.
http://www.cssbinc.com/images/ads/ho...r_for_1963.pdf
Old Dec 31, 2011 | 09:11 PM
gbarmore's Avatar
gbarmore
While you're at it just pull the body and do a frame off, that's what happened to me. No kidding, the power steering control valve was leaking and it got WAY outta hand.. I'd say don't let your repair get out of hand but it is fun. Happy new year!
To How do I fix this leak?
